Results 1 to 15 of 24
Thread: My 2nd 350x Build (this time a 1986)
    Nov 2010
    Lake Wylie, SC
    139
    Well the story goes, bought my 1st 3 wheeler, '85 200x 2 years ago , then got an '85 350x last summer, Click image for larger version.
ID:	157325, pics are after I redid them.
    Unfortunately, earlier this summer sold the 200x , to get 2 of my 3 boys dirt bikes. Then this summer when riding with them, rode somebodys crf250r, I just had to get one of those, Click image for larger version.
ID:	157326, ended up selling my '85 350x Click image for larger version.
ID:	157327 for a really good price and was able to get that bike. Been riding with the kids since Click image for larger version.
    Well 2 months later, I had seller's remorse. Really missed my 350x. Nothing is like riding that in the woods and just around to have fun.
    So last week, bought an '86 350x Click image for larger version.
ID:	157329, Fired up 1st kick when I picked it up. (Original tank, front fender, Supertrapp exhaust, All lights work, front light no cracks in lenses or plastic). Rode it briefly, to make sure all gears work, etc
    1st weekend (last weekend) tore it all down to the frame, Click image for larger version.
ID:	157330 cleaned it, painted it, bearings were all replaced. During the week, took the engine to machinist to extract exhuast studs and replace with new. Ordered a few parts. Tank sealant kit from Eastwood, decomp cable, New Old oem red fender from moshman. Had a few laying around since last build.
    Sprayed the inside of the rear maier fender red. Jus to see how it would come out. Will eventually replace with all red.
    Today, I rebuilt front shocks, carburator, put everything back together, except for engine, should pick that back up middle of week
ID:	157353Click image for larger version.
ID:	157345Click image for larger version.
ID:	157346Click image for larger version.
ID:	157347Click image for larger version.
ID:	157349Click image for larger version.
ID:	157350Click image for larger version.
ID:	157351Click image for larger version.
ID:	157352Click image for larger version.
ID:	157344Click image for larger version.
ID:	157343Click image for larger version.
ID:	157341Click image for larger version.
    One more thing I bought yesterday, front head light guard Click image for larger version.
ID:	157355 , snagged on ebay yesterday, once I get, will refinish, add some cross bars and install
    Tomorrow, sealing the tank.
    Hopefully will be able to ride in in the next couple weeks.
    Enjoy
    '85 200x -
    '85 350x -
    '86 350x - current
    fingerlakesny
    2,834
    sounds like a great build, keep up the good work...
    250r dust runner
    Apr 2010
    KS
    65
    Looks great!! Where did you get that blue front brake line?
    Nov 2010
    Lake Wylie, SC
    139
    Oreilly's auto parts
    '85 200x -
    '85 350x -
    '86 350x - current
    Nov 2010
    Lake Wylie, SC
    139
    Got everything back together last night. Just waiting for tank to dry to put some gas in. Hopefully riding this weekend.
    Still need some tank decals.
    I must of been the first one to repack that supertrapp
    Got my hondaline headlight guard the other day, and added 4 bars across.
    freshly painted
ID:	157566Click image for larger version.
ID:	157567Click image for larger version.
ID:	157568Click image for larger version.
    '85 200x -
    '85 350x -
    '86 350x - current
    Nov 2010
    Lake Wylie, SC
    139
    Video of first fire up once all put ack together
    Phttp://m.youtube.com/watch?v=S_g0KxVy5qo
    Let's see if this works. Fired up the x tonight for the first time. Took quite a few kicks to get her going. Once she did, she sounded real good. supertrapp is amazing.
    Need to fine tune little bit tomorrow.
    Question though, I did adjust valves, when engine was out. All needed minor adjustment. Was able to freely move the ..003 gauge thru and 3 out of the four Valves . I was actually able to move the .004 gauge thru them. So I adjusted to where the .003. Just grabbed a little then tightened everything down . I assumed I did the valve adjustment correctly? Then reinstalled the decomp cable when engine was on trike.
    Let me know what you think, thx
    '85 200x -
    '85 350x -
    '86 350x - current
    Southern MN
    1,875
    When you re-set the valves, did you pull the little plugs on the stator cover, turn the motor over with a 17mm socket, and allign the "T" mark to top dead center? You need to be sure the piston is at TDC before adjusting them, otherwise you could be adjusting them while one valve is slightly open on intake or exhaust stroke. I would think if you did it incorrectly the top end would be very noisy, but it would also make it harder to start. Be sure to do a plug chop before riding her too hard. I just put a DG pipe on mine, rebuilt the top end with high comp piston, and took it for a ride. It is running lean on mid range (Needle Jet circuit) and also on top end (main jet). I havent gotten to a shop yet to pick up a couple sizes larger main jet, but after that I plan to raise the needle clip one position in hopes to take care of the midrange lean condition. Let me know what you find! Looks really nice! ---- Jon
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Nov 2010
    Lake Wylie, SC
    139
    Yes I did have at tdc. Both rockers were moving freely,
    Went by the service manual that I have. I was kind of concerned b/c when I first bought it fired after 1-2 kicks. But once I tore all down and put back together after cleaning rebuilding it took a little longer.
    Haven't rode it yet, just ran at idle to work out some kinks. I didnt hear any valve tap tonight. Engine hummed pretty good, but of course was really listening at supertrapp. Bike was running 5 disks when picked up, but I called supertrapp, and they told me to start at 8 and work down.....
    I'll post again after I put the tank on thurs or Friday
    '85 200x -
    '85 350x -
    '86 350x - current
    Nov 2010
    Lake Wylie, SC
    139
    Quick update, took it out today riding. After some carb tuning, adjusted valves, this thing is awesome.
    No ticks, no funny noises, and even better, no smoke..
    Got it to start on 1-2 kicks now. Dialed in decomp cable, running stock slow jet, main went from 138 up to a 145. Air screw 1-1/2 turns out.
    Supertrapp muffler with 7 disks, uni-filter, and can only assume stock engine....
    Of course will have to do all over again once my 400ex carb arrives. Should be here early part of week.
    Tomorrow I'll post pics, plan to go out in the woods and get her muddy?
    Parts still needed, in search for:
    Prm swing arm skid plate
    Oem red rear fender
    Tank decals
    350x seat cover
    '85 200x -
    '85 350x -
    '86 350x - current
    Nov 2010
    Lake Wylie, SC
    139
    Quick update,
    Got the 400 ex carb yesterday, went thru it, cleaned it replaced old parts, and installed little bit ago.
    Had to start all over with tuning
    Kept the 42 slow jet in it. Had to go up to a 165 main. And I still have a little pop at decel. Plug is good, but will prob go out and pick up couple more jets to see where it will go, thinking 170/175?
    '85 200x -
    '85 350x -
    '86 350x - current
    Nov 2010
    Oshawa, On, Canada
    2,123
    The poping on decel would most likely be your pilot jet that needs to be a few sizes bigger.
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    Nov 2010
    Lake Wylie, SC
    139
    Oh, I have a 42 in there, I do have a 45 I can try?
    '85 200x -
    '85 350x -
    '86 350x - current
    Southern MN
    1,875
    Before you replace the pilot jet, try adjusting the fuel screw on the bottom of carb. You need to go out with it to make it richer. Try 1/2 turn at a time, ride it, let off the throttle and see if it pops. If it does, go another 1/2 turn, and eventually it will go away. If you have to go more than 1 1/2 turns out, that means you need a larger pilot jet. I got mine to stop popping on decel, but I ended up going too far out, so I need a larger pilot jet. Good luck!
    85 Yamaha Tri Z 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    81 ATC 200
    Nov 2010
    Lake Wylie, SC
    139
    Today, I thought I'd try making some of my own wider foot pegs. Had some 1/4" aluminum stock and shaped into some wider pegs. Mounted and installed.
ID:	157984Click image for larger version.
    '85 200x -
    '85 350x -
    '86 350x - current
    Nov 2010
    Lake Wylie, SC
    139
    Went riding day after Thanksgiving. Good day, had the new 400ex carb installed, fun.
    Ended up jetting, 45 slow, 165 main, 3rd position on needle. Installed new rebuild kit in it last week.
ID:	158495Click image for larger version.
ID:	158494Click image for larger version.
ID:	158496Click image for larger version.
    '85 200x -
    '85 350x -
    '86 350x - current
