Thread: Atc 125m won't idle
    Aug 2012
    johnsburg ny
    61
    Atc 125m won't idle
    I have a 1983 atc 125m and it will not idle at all and I have had the carb totally cleaned
    A couple times and I have turned the idle screw all the way in and it doesn't do anything.
    Any suggestions?
    Nov 2010
    Oshawa, On, Canada
    2,123
    You have a few possibilities, Pilot jet could still be clogged. Plug could be fouled, air filter could be mega dirty, bad gas, low compression...
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    fingerlakesny
    2,834
    yep, what jason said.... 1 little itty-bitty piece of dirt wwill cause a problem in a carb... good luck
    250r dust runner
    Aug 2012
    johnsburg ny
    61
    Ok thank you I will try all of what you said
    MN
    3,263
    Sounds like you still got something plugged up, its a pain. I took a 125 carb apart three times before i finally got that sucker to work right once. The third time i said the heck with it and soaked it in carb dip for two days then blew it out and baked it under a heat lamp for an hour and blew it out again, it must have worked cause after i put it all back together it ran good.
    On the other hand, i just had another 125 that i could not get the carb to work right on no matter what i did. I ended up buying a new replacement carb off ebay, then i had a racing idle. Ended up being the gaskets between the carb and the intake and the intake and head if you also removed the intake tube to get the carb off, i know when i take apart a 125M i take the two bolts out of the head end of the intake and take the carb and intake off as one piece. Turns out it was just an air leak. I ended up making two new gaskets from a sheet of gasket material and a new o-ring for the front of the carb from the hardware store and it purrs like a kitty now.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Jun 2018
    Holland Mi
    93
    So then is the carb screw towards the engine the idle mixture screw and the one towards the air cleaner the idle screw ?
