Results 1 to 14 of 14
Thread: YTM200E idles WAY too high.
    Nov 2012
    Jersey shore
    13
    Hey Guys... new here. I have an '84 YTM200E, and when I start it, it idles crazy high. If I slightly restrict the air flow going in the carb, it loweres, but is very chokey. (is that a word?) It was running OK without an air cleaner, but put one on, and it would race. Now it's all the time. I have the idle screw in all the way, and tried various mixture screw setting with no luck. Could it be the needle valve seat?
    Also, the mix screw is on the bottom, nest to the fuel bowl, right? There s a screw on the side, where you'd normally expect to find the mixture screw, but it's not it. I tried removing the choke slide, and put a bolt in the hole, and it kinda worked, but right back to crazy idle. What to do?
    Also, Where would a good donor carb come from? I see BW200 has a clamp on flange, so that's out.
    fingerlakesny
    2,834
    did it ever run good and now this is happening or has it always idled hi ?
    250r dust runner
    Quote Originally Posted by lakesidewelding View Post
    If you are talking about the idle adjustment screw, not the "air screw" or whatever those carbs have (I'm not completely familiar), and you did indeed turn the screw all the way in, you have effectively turned the idle all the way up. Clockwise (in) raises the idle and counter-clockwise (out) lowers it.
    Nov 2012
    Jersey shore
    13
    It used to run OK, then decide to rev way up, then be fine. Seemed like when it was low on gas, or so I thought. Now it is just all the time.
    I tried the air screw on the bottom all the way in, as well as 2 1/2 turns out, to no effect really. The throttle cable is a little tempermental. If I move it around, it changes the idle as well. I guess I should change that, too. The choke cable has a bit of slop in it too, and doesn't want to pull out more than a 1/4 of the way.
    I had read the rebuild kit for the Timberwolf is the way to go for a rebuild.... thoughts/feelings?
    maxdallasfan's Avatar
    maxdallasfan is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    New Jersey
    381
    How is your oil level?
    Nov 2012
    Jersey shore
    13
    oil's fine. Love the Marty Feldman avatar by the way!!!
    fingerlakesny
    2,834
    well sounds lke your cables are shot and it was low on gas and then you adjusted all the jets and now your wondering whats wrong... fill it with gas , clean the carb and set the jets 1 1/2 turns out ( check for air screw settings= factory set )for starters and that should get it 2 run so you can fine tune it... good luck
    250r dust runner
    Nov 2012
    Jersey shore
    13
    Thanks for the input... I really appreciate it.
    Nov 2010
    Oshawa, On, Canada
    2,123
    You have an air leak.... i'll bet my R on it. Spray wd around the carb to find it ..
    if it was your needle valve seat it would piss gas out of the overflow.
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    Nov 2012
    Jersey shore
    13
    Oh yes, she pisses as well. And also, I disconnected the throttle cable from the throttle lever, and no change in crazy rev. I had originally thought air leak, but the manifold boot is beautiful, and seal seems good. I will double check that as well. Thanks for the thought!
    Nov 2012
    Jersey shore
    13
    Took the carb off and checked the needle seat/valve, and is in working order. I think I am sucking air through the choke cable. I took off the choke cable and blocked off the port and the idle went down, but not all the way. I think the throttle cable is bad, too. They're cheap fixes, and seem like a good direction to go in.
    May 2011
    eden,ny
    3,481
    I don't recall the air screw being on the bottom,I know on my ytm its on the left side of the carb. I know its common on the knock of carbs for the air screw to be on the bottom,if you have a chinese carb on it good luck. check to be sure the slide is returning all the way,all it takes is one broken wire in the cable to hold it up.
    Nov 2012
    Jersey shore
    13
    The carb is a Mikuni. The fuel bowl is kinda notched around it, so you have to take the carb off to get to it Pain in the ass, really. There is a screw where the adjustment screw is on every other bike I've ever worked on, but it seems like it is just an air port... like for linking multiple carbs together, I am guessing. If you loosen that screw, there is no spring behind it, and it just sucks air, as it is literally just a bolt hole. Weird wild stuff.
    May 2012
    ELk Garden WV 26717
    55
    The idle screw should have like a plastic nob on it, Start it, Turn that bolt out ti'll it dies, turn it in half a turn, then adjust from there, thats how i did it.
