LED's are DC only. So no you couldn't, unless you wired in a rectifier/regulator and added a small battery to filter the output and stabilize the DC voltage for the LED lights, without the battery or a large capacitor on the output of the rectifier/regulator the LED lights will flicker.
Stock is a 55w light on high beam, the low beam is 35w i think.
1984 Honda ATC200ES "Big Red"
1982 ATC200E "Hondie"
