Thread: 84 ytm 200e
    Nov 2012
    tennessee
    Angry 84 ytm 200e
    I need to know where to get 10 inch wheels to fit this trike ive looked everywhere cant find any
    Nov 2012
    Jersey shore
    13
    You'll probably need to either get a set of blaster wheelsand re-drill them, or use the rims and hubs off of a blaster. I just picked up a set of blaster wheels for $40, so they can be picked up cheap enough. You'll need to make a template with a compass/protractor, (I got them at Walmart for $3.99). The Blaster wheels are 4x100mm and the YTM's are 4x125mm. I used a piece of sheet metal small enough to fit inside the blaster wheels, and layed out the 2 sets of holes (looking like an 8 lug). once drilled for the blaster wheels, bolt the plate to the rim and drill the new hole pattern.
    Nov 2012
    earth
    10
    I would check on ebay. They have lots of parts for trikes
    glendive, montana
    1,822
    are you sure you want 10 or the stock 9 inch rims, that fit the 25-12-9 tires, or are you trying to change it to actual 10 inch rims? I have a couple sets of stock rims
