Results 1 to 11 of 11
Thread: Carbon removal from pipe..
    blackstone/ma
    1,491
    What is the best way to get carbon out of a pipe? Looked or a thread on this but didn't see one.
    Nov 2010
    Oshawa, On, Canada
    2,123
    I let my the exhaust on my x soak in oven cleaner for a while, kept shaking it, cleaned it out real nice, and when i started it, it blew the rest out.
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    Springfield Mo
    3,309
    Remove from bike, fill with kerosene burn in fire.
    RIP Ninja!
    Trike Fest 2011, 2012 Vet!
    Trikes Currently Owned:
    87 Big Red 250es
    83 Honda 200s
    81 Honda Atc 70
    (4) Suzuki ALT 50's
    Yamaha YT 60
    You can hang it up with a propane torch blowing in it. Or in your case just talk into it for a while. That's more than enough hot air I'd say.
    blackstone/ma
    1,491
    Should I remove the kerosene before I burn in fire or leave it full when it's in the fire..
    Quote Originally Posted by thestud25 View Post
    Propane?? Really?? Looked inside the CRF pipe and OMG is it dirty crusty carbon build up
    Mar 2011
    Red Lion pa
    1,542
    Let me reiterate some advice you gave me on my thread
    Quote Originally Posted by TecateDan View Post
    Make sure you do this step with a cigarette in your mouth for cool points
    86 honda big red
    85 250sx
    82 250r
    86 klt 185 black (project)
    86 klt 185 red
    85 klt 160 (Floyd)
    85 klt 110 X2 (projects)
    86 klt 110 X2
    84 klt 200
    84 atc 70
    DUCKSTER!
    Springfield Mo
    3,309
    It won't hurt to leave it.
    RIP Ninja!
    87 Big Red 250es
    83 Honda 200s
    81 Honda Atc 70
    (4) Suzuki ALT 50's
    Yamaha YT 60
    Jun 2012
    hinsdale,ny
    120
    Part solvent works good
    82 250r's Avatar
    82 250r is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2007
    Utah
    278
    Torch
    Oxy acetylene torch... 2 ways to do it.
    1. Heat up the manifold end red hot and blow compressed air into it. A red ring will slowly move to the end of the pipe when all carbon is burned. I have never tried this method.
    2. Slowly heat the entire outside of the pipe (Red Hot) with the torch. (Propane works but much slower than acetylene).
    I have done this and it works excellent. Start at one end and work around the entire pipe. Be patient. You know it's done when it stops smoking. You may need to prelate chrome pipes.
    Blow out with compressed air and your done.
    Marc
    honda4h's Avatar
    honda4h is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    ottawa ontario
    361
    start a bon fire nice and hot throw the exhaust in for the night cherry red. to pass the time bud or crown royal will do the trick
    watch the beginning of this..
