Results 1 to 12 of 12
Thread: Big red...special reverse?
    Psyonyde is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2003
    157
    My dad told me he had an 84 big red, that had 5 reverse gears. He said he had the tranny worked on, and that they had installed the additional gears for some reason. Anyone know if this was possible, or if he was just pulling my leg?
    1983 Honda 200e
    1984 Honda 200es (needs rebuild)
    1985 Honda 250es
    1986 Honda 250es (parts bike)
    1984 Honda 200es (parts bike)
    Crash104936221 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Gananoque, Ontario
    223
    my stepfathers bigred 83? has 5 hi 5 low and he said he could of gotten a aftermarket part the cam out a year after he bought the bike (new) that would of gave it revese
    now i could see this interfacing after the trans and giving 10F/10R
    or even changing some grears in the trans to have a HI revese that used all 5 gears < mabie this is how it worked and that what your dad got?
    Joe
    81 ATC200
    Jun 2003
    157
    Maybe, I'm not sure. All he said was that he had gotten one of his friends to work on it, and that it came out with the 5 reverse gears.
    1983 Honda 200e
    1985 Honda 250es
    May 2003
    Shediac, New Brunswick
    1,126
    Quote Originally Posted by Psyonyde
    maybe this friend messed up lol.. and he had 1 forward gear and 5 reverse gears.
    '84 Honda 200x
    slow restro
    Mar 2003
    Australia
    1,919
    Id say hes pulling your leg, then again nothing is impossible :-D
    1980 ATC 70 Needs Restoration
    1985 ATC 250es Fully Refurbed
    1986 ATC 350x Mint Original
    Curtis-Tecate3's Avatar
    Curtis-Tecate3 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    352
    My memory is a bit hazey on this subject but I do remember ad's in 3wheeling about a reverse kit for the big red. I dont remember which year it covered but it would make sense that it was the model with the dual range gear selector. I would assume that it would add reverse but eliminate the low range option.
    I will try and dig out my magazine collection this weekend and confirm.
    Curtis.
    I love anything with an engine except a lawnmower...
    1986 Tecate and original owner of a 1985 200X.
    3 wheeling since 1975.
    352
    I just dug out my old magazine stash and the reverse kit is advertised in like every issue. The company was called Paltech in Palatka Florida and they offered a reverse kit for 82/83 big reds for $99.00. It says 30 minute installation. Basically it changes the Hi/Lo subtransmission to Hi/Reverse.
    Curtis.
    Jun 2003
    157
    He didnt have 1 forward, and 5 reverse. He had 5 forward, and 5 reverse. Also, Curtis-tecate, do you know if those 82/83 reverse kits are still available.
    1983 Honda 200e
    1985 Honda 250es
    I have an 84 big red
    I just bought an 84 atc200es "Big Red" it has 5 gears in High Range, 5 gears in Low Range, and 5 gears in Reverse.
    Nov 2002
    Kirkville, NY
    3,831
    The Honda 200e had electric start and hi/lo. The hi/lo meant that it had 5 gears in hi and 5 gears in lo so when the reverse kit was added it would still have the 5 forward gears in hi and 5 gears in reverse. The Honda 200es ( electric start and shaft drive) can from the factory with a hi/lo/reverse trans.
    -Andrew
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    the high/low/reverse is a second set of gears after the main 5 speeds. there is a linkage that prevent you from shifting into reverse in anything but N or 1, and prevents you from shifting higher than 1 in in R. if this linkage is broken, you will have all 5 gears in R.
    Jun 2003
    157
    I was just talking to my dad about it, and he mentioned something about linkage (or something like that, he was kinda mumbling) or that they had bypassed something, I'm not sure. I think thats what it was though
    1983 Honda 200e
    1985 Honda 250es
