Thread: What will fit my 1986 Honda 200s?
    Oct 2012
    Syracuse,NY
    10
    I have found out Honda no longer make parts for 3 wheelers.
    Also it's really hard to find aftermarket parts that fit them.
    With this being said I need to know what throttle cables/carb slides/carb needles will fit my 86 200s.
    Will ANY honda 200 3wheeler cable/slide/needle fit?
    I really hope so.
    I need my baby running again.
    Michigan UP
    1,005
    Try a Honda dealer, if OEM parts are no longer available they should be able to get them from an aftermarket supplier like Parts Unlimited. I get all of my Honda parts from a local Yamaha dealer, there are many aftermarket catalogs that they order from.
    Yeah, I don't know what your sources are, but there's still quite a bit of stuff available for that machine.
    MN
    3,263
    Tons of stuff...
    www.dratv.com has a bunch of oem and aftermarket parts available for it, and there is plenty on other sites as well as ebay. There is even full aftermarket carbs for them.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Cornholio's Avatar
    Cornholio is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2012
    Staples Minnesota
    180
    Im thinking that any motor parts from 83 - 86 for 200s's are the same. I believe that they did not change anything from 83 to 86, so you can get a carb for any year 200s and it should fit. Before 83, I think the only difference was no decompression lever
    Life is short, Party naked!
    1986 250r
    1984 200s
    1984 250r
    1970 us90
    1991 Yamaha Blaster
    1984 110
    1985 110
    1984 200x
