Thread: atc 200M how to take off the fork stem nut
    Oct 2012
    Finlayson, Minnesota
    1,066
    Ok Well i wanted to replace bearings in the front fork of my honda but I cant get the thing off for the life of me! The nut im talking about is the one that's holding that stem in the neck part of the frame. I put a screw driver on it and beat it left and right (not sure if threads are reversed) and nothing. I heated that sucker up (even melted my rubber seal a little!) and still nothing. I then put a chemical that breaks the rust and then some lube... and still NOTHING. What is the best way to remove that nut??
    Thanks,
    Cody
    Howdy's Avatar
    Celina, Ohio
    10,079
    It's the standard Lefty - Loosy / Righty - Tighty style nut. It's possible that it is jammed on too tight and could be a real bear to get off.
    Howdy
    fingerlakesny
    2,834
    try a pipe wrench.. sounds like youve got a nasty one...
    250r dust runner
    Jul 2011
    Eau Claire, WI
    1,188
    Air .
