Results 1 to 7 of 7
Thread: A quick note to the sled owners with air cooled engines..
    Sarnia, Ontario, Canada
    3,415
    So backstory is..I was 15 and had bought a 1978 Yamaha SL338 from a buddy for $300 near the end of the winter..
    I got 2 or 3 rides then the snow melted and the machine parked..I found a nice spot in the barn. Cleaned it up really nice and covered it to keep the pigeon shlt from making it dirty..
    The following winter..1st snow fall and I'm riding home on the school bus feeling pretty horny to ride my sled. Run to the barn and uncover the machine, fill the tank and got it running in a couple pulls of the cord.
    Grab my helmet, gloves and warm coat and off I go..flying down the snow covered road. About 3 miles from the house..BOOM and I suddenly lose all my power..managed to limp back home the machine barely running on one cylinder.
    I open the hood and start pulling the shrouds off the engine..there before my eyes is the biggest damn mouse nest packed up in the shrouds completely blocking the passage thru the cylinder fins..
    Once I got it apart I found a dime sized hole in my #1 piston..
    Fast forward 30 years..I get this great little 98 Indy Lite.
    The 1st snow fall I take my daughter out for a short ride..near the end of the ride is starts to sputter a bit but no worries we're done and I trailered tha machine..
    On the way home I started to think about the possible reason for the sputtering.
    I decided to investigate..as I opened the hood I see small bits of what looked like fiberglass insulation sprayed around the engine compartment. 5 minutes to remove the shrouds and guess what I found? A big azz mouse house in the fan housing!!
    Thankfully no damage resulted.
    Moral to the story guys..before you jump on your sled and take that 1st ride. Check it over..you could save yourself a world of pain.
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Dec 2011
    Grand Rapids, MI.
    679
    This is a pretty common problem, one way to prevent it is to put something such as socks or dryer sheets in all openings such as the exhaust and air filter when storing your sled for the off season.
    1986 KLT 185
    1984 200S
    ontario
    1,131
    Oh ya you always have to go over them with a fine tooth comb before you get to ride them lol always have to make sure the carb's are clean and set as well or your like my dad and having to rebuild the top end. Click image for larger version.
ID:	158691Click image for larger version.
Name:	dads sled engine 2.jpg
ID:	158689Click image for larger version.
Name:	dads sled engine.jpg
ID:	158690 sorry for high jacking your thread doug
    1984 110 project
    1984 125 parts bike
    1983 honda 200x
    19 85x2honda 200x
    1985 honda 250sx
    1985 honda 250es
    MN
    3,260
    Been there done that, the next year when you put it away get a box of moth balls, rip the top off the box and tuck it under the hood with the motor, kept the little buggers out of my sled on the farm for years, they just hate the smell i guess. Problem i usually had was them crawling up into the muffler and building a home in there, a ball of steel wool in the end of the exhaust kept them out of that.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    NEPA
    7,051
    Even more than air cooled fans and pipes,,they LOVE air boxes. It only takes a little while to go through your sled,clean,grease,adjust and KNOW you'll be happy out on the trails : ))
    3,415
    Quote Originally Posted by atc007 View Post
    Funny you should meantion that..
    I went the other day to look at a 2004 Polaris 500. Condition was a bit rough, but not bad..seller tried to tell me it was from his cabin up north and he just didn't need it anymore..
    Told me how he pulled it from storage and tried to start it, then realized it had a big mouse nest in the airbox..he cleaned it out and got it running.
    Boy did that thing run lumpy..oh yeah he says, it could use a carb cleaning.
    When I started to back away he dropped his asking from $1600 to $1000..I knew then I had a machine with a serious issue and left it where it sat.
    My money was on the truth that the mouse nest probably got sucked into the carb and was probably running thru the engine. No way I was buying a machine that needed the engine split to remove mouse house!
    Current toys..
    1990 Honda TRX300FW
    1995 Seadoo GTX
    Oct 2008
    NB, Canada
    852
    The same thing goes for any ride-on/lawnmower engine. Mice love to build a nest under the engine covers.
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    Always Hoping For a Maritime Trikefest- http://www.3wheelerworld.com/showthr...s-where-you-at
    "Wear Limits Are Just A Suggestion"
