T3 compression #'s?
Sorry for all these posts, but my manual is not accessable right now.
I need to know how much compression an 84/85 T3 should have.
thanks.
thanks sean.
Now I can get to the bottom of this stubborn T3....
got the weak spark sorted... now to see how much pressure this thing has.
ok, so my gauge is only showing ~130 psi.
Now, could the reeds be weak enough that they leak pressure back through the carb? So before it gets to the top of the compression stroke I loose some PSI?
Just trying to fix the simple things before re-doing the top-end.
//ArrowChat Integreation Code
