i got an 85 250sx, just rebuilt the carb with manual in hand, one piece at a time. cleaned it out with air and carb cleaner. reassembled the carb and put everything back on the trike. new gas cap (old ones air vent did not work), and external filter. got it to start up with choke on until warm and had it idling smoothly choke off. had to re adjust throttle stop. gave it some gas sitting there and was ok for the first few times then if you gunned the throttle it would bog down and almost die, if i eased into it it had no problem. took it for a spin got 50 feet and cut out completely. back into neutral and started it up again. idled fine and i touched the throttle and it bogs down quick and dies.
so i got steady gas flowing. the tank fuel filter is clean, the external filter is clean, steady stream to the carb. trike will start and idle fine. cant touch the throttle or it will bog down and die, but will start back up. iv rebuilt the carb correctly. and cleaned the jets and air ways and seats. the float works and does not leak. everything i took off went back on, all replaced parts were replaced properly.
does anyone know what is wrong with this carb not working right. the last thread i wrote was about the bogging down issue. i was told to rebuild the carb. in doing so, i now have more issues.
