checked the exhaust last night. clean and free flowing as could be. no restrictions. checked the air box intake tube and inside the frame, clean as can be. put the trike back together, and gave it a shot. still can get it to start and idle fine. choke cable and and choke plunger work correctly with no damage to small needle. a quick push on the thumb throttle and it comes close to stalling. ease into it and i can hit high rpm, release throttle and it drops back to idle. every time i gun it it stalls or comes close to it just as i back off the throttle. shut it down and tore it apart. took the carb off, disassembled it cleaned it with carb cleaner and the air hose. took all the jets out and cleaned each one and the air ports and gas ports in the carb. reassembled the entire carb and trike. emptied the tank, fresh gas, cleaned the spark plug (to help tell me what new stuff is on it), used the air filter out of the big red, started it up, idled fine, let it get warmed up some, gave it some throttle and i get the same response from the trike as i did in the beginning of this thread. might still having trouble going from slow jet to main jet. also the spark plug tip was black but not wet. the main throttle needle IS set to the correct notch and i used a manual to rebuild the carb.
dump a little gas down the spark plug whole.....she'll start.
