Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
Thread: Ethanol the enemy
    WNY
    124
    Ethanol the enemy
    Found this video on another forum & thought it might interest some of you who are concerned about phase-separation occurring in today's oxygenated fuels .
    I've used Seafoam for years , but after seeing the side-by-side comparison ( in glass containers ) I'll be switching teams .
    Have a look : http://www.veoh.com/watch/v27896358P59eQY2h
    Lancaster, PA
    1,738
    wow, interesting
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    Jul 2011
    Eau Claire, WI
    1,188
    Thank you Angore! This was educational.
    I will no longer use Sea Foam in my fuel.
    Van down by the river
    3,874
    Very good video, Thanks for posting.
    R.I.P. John Swinehart
    Epic Mikfest 17
    86 200x
    85 250sx
    85 big red
    85 atc 70
    WNY
    124
    Your welcome ! I didn't say not to use Seafoam , I believe it's still a great "system-cleaner" it just doesn't prevent phase separation like the other one .
    I'm going to be using a little of each
    Jul 2011
    Eau Claire, WI
    1,188
    I always use Sea Foam in the brake booster of my vehicles once a year. And also in the crank case before oil changes. I've actually been using Lucas Oil fuel system cleaner.
    Oregon
    2,471
    Very important for the 2 stroke fans, Thank you for sharing.
    If you have Bought a item from me, Please leave me feedback
    If your buying a item from me check my feedback
    Click on link ~ http://www.3wheelerworld.com/showthr...ceaserthethird
    Jul 2011
    Ontario/Quebec
    1,179
    1986 Honda 350X
    1985 Yamaha Tri-Z 250
    Wichita, Kansas
    1,361
    I'm Pro e85 ethanol, all the way. Currently.
    I'm writing this as i watch this video.
    Ethanol makes more power than gasoline, around 18%. This is true for engine built for e85, not for premium and ethyl. At its peak power, it does release 4.4% more heat. But that can be toned down to equal that of gasoline. e85 does not hurt anything on vehicles these days.
    ------------ AFTER WATCHING ----------
    Neat!! I have a new chemical at my disposal I like lol
    I <3 my high performance e85, 105 octane ethanol:-D
    Never had an issue with water separation with it. But I also don't let it sit for ever. I buy it and use it lol.
    Mar 2003
    Nashville, Tn
    114
    Thanks for sharing for sure!
    1984 atc70
    1985 atc70
    1985 Atc200s
    1986 atc125m
    1986 atc250r
    1986 atc350x
    1987 atc250es
    MN
    3,263
    I have been using Stabil for about 20 years now... Never have i had a problem with stale or separated fuel using it. I just started my walk behind snowblower yesterday, been sitting since last year with Stabil treated fuel, fired right up... Ran for fifteen minutes, checked over everything and then added some fresh fuel to the tank to top it off... Good to go.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Mar 2008
    EastGreenbush, newyork
    3,494
    cool video! I will give it a try, i have used alot of others, but never heard of that! I usually open the drain screw on the float bowl for 8- 10 seconds! works every time!! great for the cans, saws, generator etc.
    Aug 2010
    Southern Oregon Coast
    932
    I'm glad I can get non-eth fuel.
    MN
    3,263
    Quote Originally Posted by falloutboy View Post
    Non ethanol fuel isn't that big of a deal.. Just like anything you have to know how to deal with it. There is a lot of good products out there to take care of it, and no reason to be totally concerned over it. If your really really paranoid you can put a water trap on your fuel line or get a fuel dryer setup to dry down the fuel before putting it in the tank. Pretty interesting setup i have seen some of the pro lawn care guys using, especially the tree service guys around here. It's a 5 gal gas jug with an element in it that absorbs the water in the fuel, not sure if its like a dessicant type product or what it is, haven't researched them.
    I just toss in some Stabil every time i fill up my jugs which i fill all the machines off here, trikes, saws, generator, mower, snowblower, etc etc.. They make three different types now, the standard red for treatment and storage, green for marine use, and yellow/gold which is just for water bonding in ethanol blended fuels. I have poured the ethanol treatment in just about everything as a precaution when its really humid in the summer, helps with condensation buildup in the tank.
    MN
    3,263
    I just watched that video again.....
    I would like to argue one point that he made.
    "It sucks from the bottom of the tank first"
    Ok thats somewhat true... But none of them take from the dead bottom of the tank, they have a filter or fuel inlet, or both, that goes up into the tank from the petcock. Sure if you run on the reserve setting on say your Honda ATC you can pull from the bottom, but even then you won't pull from the dead bottom but slightly above it, thats why the bottom of the tanks get rusted out from the water sitting in the bottom of them. I drain the tank down every spring and every fall, the remove the petcock, drain whats left in it out, use a rag and a air nozzle to fit the nozzle to the filler cap and blow air through the tank to force any water or gunk out and then flush with a bit of fresh fuel and re-assemble and refill. Why? Just cause thats how i was taught to take care of equipment with metal tanks.
    He wouldn't say the names of the products.... But the first one he poured in, the right end of the row, isn't Stabil and i am not sure what it is with certainty but i know Stabil products very well and that ain't it. The second is the one hes touting... And the third one, the left end, is Seafoam for sure, unmistakeable because of the container top and lid, who hasn't used Seafoam that wouldn't recognize it...
    I haven't ever heard of anyone using Seafoam to treat fuel specifically, it shines for what it was made for, a fuel system CLEANER, yeah sure it treats the fuel, but only to the extent that its mixed in so its carried through the fuel system to clean it. The company doesn't claim its a water killing product. So the guy in the video isn't really comparing apples to apples but its just another nit pick of mine.
    Its a neat looking product, i would definitely give it a shot if it was sold locally, but i haven't seen any source of this product around here so i will continue using Stabil. Last i checked there wasn't any visible water or separation in my 2-cycle jugs or my saws.
