Page 2 of 2 FirstFirst 1 2
Results 16 to 29 of 29
Thread: Time for another Port Job - YT125 - Pics on page 2
    Lauderdale County, Alabama
    2,029
    I've been waiting for you to do up that 125 forever man! Keep in touch on it.
    Wichita, Kansas
    1,361
    :-p It only took me.. what? 2 years? lol
    I'm not going to make a screamer, simply because who it's for.
    Wichita, Kansas
    1,361
    I decided to go with a 180 exhaust and a 124 transfer duration. I figured it would match the original 175 pipe a little better.... thats my excuse and im sticking to it.
    Truthfully i just want a little more umpth from it lol
    Wichita, Kansas
    1,361
    I got most of the porting done now. I decided to go with a muliple transfer timing. 124 closest to the exhaust port, 124.5 on the next set of transfers, 125 on the intake.
    I widened the transfers some. I reshaped the transfers at the base. Made them appear useful. Reshaped the intake track a little, made it contour into the main intake port better. Thats about all i did. Should help this little guy out a ton. I need to get pics. Give me a few minutes.
    Wichita, Kansas
    1,361
    Well I didnt take many pictures. The cylinder is way beyond this stage. These are prior to cutting and reshapping the base.
Name:	stock transfers right side.jpg
ID:	160766 Stock Transfers in cylinder
ID:	160765 Stock base
Name:	stock transfers.jpg
ID:	160767 Stock Transfers on the base
Name:	raised exhaust.jpg
ID:	160768 Raised and slightly widened exhaust
Name:	sleeve cut back.jpg
ID:	160769 Sleeve cut down to open the transfers
Name:	Transfer widened.jpg
ID:	160770 left transfer widened in jug. Maker is where the rings meet. (roughly)
    I'll get more pics this evening.
    Mexico
    9,018
    Have you placed the cylinder onto the case halves individually to check for obstructions and mismatched surfaces? Great post!
    Wichita, Kansas
    1,361
    Nope, but thats not a bad idea... I do have a spare case already seperated sitting around!
    Normaly i just stick grease on the case and put the jug on there. See where it leave it's mark.
    Mexico
    9,018
    I’d never done it before, always just focused my attention on matching the cylinder base to the cases and, smoothing the transfers ports where they meet the cylinder and a little smoothing and raising of the exhaust port as I don’t have the tools to raise the transfer ports. However, on my last project I wanted to experiment with case stuffing and took the time to drop the barrel onto the case halves to see how they lined up. I was surprised to see what kinds of angles and sharp turns the factory machining and casting restrictions leave. Because my induction tract is in the cases and not in the barrel you may not have as much to deal with, but any sharp edges you can smooth out should help throughout the power-band. The only danger I can think of is that you remove so much material that you lose bottom end, hence the need case stuffing. I look forward to hearing your engine run on a video.
    Wichita, Kansas
    1,361
    Case stuff.. Yeah, its a compromise of top end and bottom end. I know the newer bikes(YZ125s and what not) run close to a 1:1 ratio on space of the top and bottom. The older bikes built more pressure below for that bottom end.
    Im going to have to look into matching the jug to the case. I wasnt going to.. but now that you mention it i need to. I'm not going all our by any means, its for the kid >.<
    I may pull my 175 apart and do some more work on it
    Nov 2008
    Coon Rapids, MN
    956
    Thanks for the pics. Alex
    1982 Yamaha YT125 tri-moto - Boyesen power reeds, YT175 front suspension, Headlight guard.
    1982 Yamaha YT175 tri-moto - Running but ugly
    1984 Yamaha YT 60 tri-zinger - Boyesen power reeds
    My feedback.
    http://www.3wheelerworld.com/showthr...ght=old-yellow
    My album
    http://www.3wheelerworld.com/album.php?albumid=98
    Mexico
    9,018
    Quote Originally Posted by RubberSalt View Post
    its for the kid
    LOL! Yea, right! Just as soon as you finish testing it, breaking it in, making sure it’s stable at speed, etc., etc., I’m guessing it’ll need a rebuild by the time you hand it over!
    Wichita, Kansas
    1,361
    SHHH
    or every one will know!!
    So true lol
    Wichita, Kansas
    1,361
    Time for port job #3 another YT175. I've learned sooo much in the past.... 13 years!!
    Lol I’ve picked up some IT175’s for a swap to after reading the threads years ago lol
