Results 1 to 10 of 10
Thread: Fork Tube Stuck
    ZacH_GrifF's Avatar
    ZacH_GrifF is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2011
    Pearl, MS
    405
    Fork Tube Stuck
    I recently change the tire on the front of my 83 185s and the fork tube boots were all cracked up so I cut them off but when I tried to pull the tubes out to replace them they wouldn't budge. I took both bolts out and nothing moved. I also want to get my fork back red instead of white but I don't want mess them up in the process because they work perfectly. Any ideas guys on how to get them out?Click image for larger version.
    1. 83 185s: (the money pit) xr200 cam, 200cc cylinder, 10.25:1 piston, 83 250r front end, 450r hubs, full suspension
    2. 85 Big Red 250es: in pieces
    3. 85 200m
    4. 00 Polaris Magnum 325 2x4: stays broke
    5. 02 Yamaha Wolverine 350 4x4: trail bike
    Oct 2007
    Minneapolis mn
    4,067
    Stick a pry bar in the slot and spred slightly...
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Great idea thanks has that worked for you?
    3. 85 200m
    Holyrood Newfoundland
    114
    Yeah i just use a thick flat head screw driver and tap it into the slot to spread it apart then i spray abit of lube like wd40 in the bolt holes and in to the slot and i just wiggle the fork tube until it slides out . They can be hard to get out some times. The pry bar would work too!
    Honda
    1985 Big Red 250-Sold
    1985 200m-Donor
    1984 200m-Parts
    1992 cr125r-Project
    1983 Auto X
    Yamaha
    1984 Ytm 200-Sold
    1999 Yfm 350-Traded
    Suzuki
    1992 lt250r
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Thanks for the info!
    3. 85 200m
    Nov 2010
    Oshawa, On, Canada
    2,123
    They usually get stuck if they are the tiniest bit bent. Like previously stated, pry it apart. For grip wrap a piece of rubber around the tube and spin with hands or channel locks..
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    Oct 2007
    Minneapolis mn
    4,067
    Quote Originally Posted by ZacH_GrifF View Post
    Sure has... It will make your life easier...
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    My next question is their anybody making boots close to OEM because their discontinued?
    3. 85 200m
    Oct 2008
    NB, Canada
    852
    I don't wanna be "that guy" but I'm just making sure you have both bolts all the way out? I figure you do, but just making sure. One of the bolts goes into a notch in the fork tube
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    Always Hoping For a Maritime Trikefest- http://www.3wheelerworld.com/showthr...s-where-you-at
    "Wear Limits Are Just A Suggestion"
    ZacH_GrifF's Avatar
    Jul 2011
    Pearl, MS
    405
    Yea there completely out of the fork.
    3. 85 200m
