Thread: Big Red is afraid of the water
    Austin, Massachusetts
    1,591
    Tomorrow i'm taking a look at my buddies 1984 Big Red 200. Thing is in great shape, runs fine all day. Drive it in any water and it stalls right away. out of the water and it starts right back up. airbox is dry/watertight. i'm thinking it must be a spark issue or some kind of bad ground or loose connection. also worth mentioning, the electric start does not work. i'm not sure if the two are related. i'm gonna try and run the problem down tomorrow. i was wondering if there were any ideas on where to start??? anybody dealt with this before?
    Oct 2007
    Minneapolis mn
    4,067
    I would look at the stator cover first...
    MN
    3,263
    If it was the stator you would have water in the oil, the stator is wet with oil on the 84 200ES Big Red and i highly doubt thats it.
    I would bet on electrical, check the connections in the boot on the left side down by the sub trans. Also pull the plug on the CDI and check that out. A little water proofing goes a long way on the CDI.
    As for the electric start, the starter relay, the interlock relay, and the push button are the likely suspects but check the starter motor actually works. You can take jumper cables or a jump box and put the negative to the frame and touch the positive to the cable connection on the starter. If it spins over then you need to chase through the wiring. The starter relay are a pretty common failure but the start button is the one i always seem to fix on the 200's.. Pull out the screw in the bottom of the handlebar control and take the button off, make sure both wires are connected in there and clean up the switch, a lot of the time the one wire breaks off and needs to be resoldered.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Oct 2007
    Minneapolis mn
    4,067
    Learned something new about the 200's... (Mine are 250's) Definately agree with KB on electrical...
