Will a 2002 Warrior, or any year Warrior shock bolt up to a Tri Z???? Need a for sure answer, I'm about to drop some dough. You guys never let me down.
Yes, any year WARRIOR shock will work. Make sure its not a raptor 350 shock, the piggyback res won't clear anything. If you still have your stock Z shock reservoir, I can build you a frankenshock...Then the bleak warrior shock will at least be compression adjustable, and look stock!
SAY IT!!!!!
85 1/2 Tri-Z - The Trail Bike w/Inverts
85 Tri-Z - The wifes Bike
85 Tri-Z - The MX/ICE Bike, 310 w/Inverts
12 Tri-Shee - The Flat Track/TT Bike w/Inverts
NYTRO - New York Trike Racing Outlaws - COME GIT SOME!
Gotcha, I did not know there is no compression adjustment on the warrior shock, I'll let you know my situation when I get the hardware, good stuff, thanks.
a raptor 660 rear shock can be an option. 2001 and maybe the 02 had the remote resi vs the later raptors that had the built in resi
Team Blue: 85 Tri-z 250: under the knife
Team Red: 87 Trx250r 01Cr80 15 CBR600RR
Team Yellow: 06 Ltr450 11 Hayabusa
Raffa, that screw on the bottom of a warrior shock is a rebound adjustment...It may SEEM like it works as a compression adjustor, but that is because without a rebound seperator nut installed, the 2 circuits overlap. Basically, the rebound will have an effect on the compression when its cranked in far enough.
SAY IT!!!!!
correct... and it works perfectly fine without spending 1k+ =) I never had a problem tightening up the spring and the rebound and running it.
Ive run the warrior shock...MAYBE for someone your size and "gumby-ness" it's alright, but definately sub par...Even compared to a banshee shock, the valving in a warrior is crude at best!
SAY IT!!!!!
I dont think hes trying to win the monster energy supercross 6000 on his z. And most people dont understand the difference no know how to adjust for rebound or compression.
Ok boys, I'm Just trying to save the guy from some spine tinglers and a cracked swinger...not telling him to spend $1000s on suspension either. Just INFORMING a fellow rider of the BETTER options for a tri-z replacement shock. I'm a big guy, so yeah, suspension means a bit more to me, so I have done my homework on cheap performance suspension for the Zs....and a warrior shock isn't one of them.
SAY IT!!!!!
