83 yamaha ytm 200k. Why is my headlight really really dim at idle? as soon as i rev it up or im driving it gets bright and works perfect. Do i need to fix somthing or is that how these are normally?
1983 yamaha ytm 200k : race cam and cobra exhaust
I've never had a yamaha.....But the old hondas did that to. Alot of times I saw folks with the idle turned down so far it would barely light........I like my idle just a bit high....I like knowing its getting the oil it needs....And the headlight stayed brighter.
Its normal, with no battery your totally dependent on the alternator/stator output. The slower the engine speed the lower the voltage output. So when you rev it up the voltage comes up.
1984 Honda ATC200ES "Big Red"
1982 ATC200E "Hondie"
You can try a slightly smaller wattage bulb. On the '82 250R, the stock bulb was a 55/60W, and it dimmed at idle, because the stator wasn't really strong enough for that size bulb. We replaced it with a 45/45W (stock size for the '85 250R), and it solved the problem; bright at idle, and even brighter at higher RPM.
Those who can ride, ride...those who can't, drive.
thanks alot guys!
