Results 1 to 8 of 8
Thread: 350x motor question on rebuilding
    Escanabajosh's Avatar
    Escanabajosh is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Oct 2009
    U.P. (upper michigan)
    352
    I picked up a 1985 350x this summer that needed a little work but ran good when I bought it,no smoke.
    I get all the little things done and it's ready for a test run. No back breaks but it ran good,kinda pulled to the one side. Come to find out the tripples and the forks were bent so I changed them and that fixed the pull.
    My fiance and I were going camping so we took along my 250sx and the new 350x. Took them out for a short ride and on the way back I opened it up, I take off like a bat outta hell big grin on my face. I turn around to see how far back my fiance is and she is right on my ass! I'm pinned yet she is still keeping up. We got back and the bike went on the trailer.
    So I dont see smoke out the pipe but figure it must be rings that are bad? any other ideas?
    I am looking at getting the ebay kit with new jug and piston and stuff for a little over $200 and was also wondering if I should do cam chain and oil pump while in there?
    if the bike didn't "blow" could I get away with pulling the jug off and using a bore hone and putting new rings on?
    Thanks for any advice/help
    Holyrood Newfoundland
    114
    Did you check the gearing and the tire size because if the previous owner put smaller tires on and did not gear up you will lose speed.
    Honda
    1985 Big Red 250-Sold
    1985 200m-Donor
    1984 200m-Parts
    1992 cr125r-Project
    1983 Auto X
    Yamaha
    1984 Ytm 200-Sold
    1999 Yfm 350-Traded
    Suzuki
    1992 lt250r
    Sarnia, Ontario, Canada
    3,415
    A bit of gun jumping going on I think there!!!
    Compression test perhaps to start to see where the motor health is..before you start tearing into the motor.
    Carb and gearing would be a good start point maybe!
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Blossvale NY
    4,563
    A 350x in stock form with it's 22" round-profile rear rubber would top out around 60-65mph.
    If you swap those 22's in the rear out for flat profile 20"s that will reduce speed fairly significantly, quite possibly down in the range of a 250sx.
    Check tire size and gearing before assuming your engine is toast. From what you have posted I seriously doubt your engine is shot.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    blkstangman88's Avatar
    blkstangman88 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2010
    marysville
    282
    if looking for speed pop a 14 tooth up front. i did that and stock rear sprocket. my woman's yfz450 was clocked at 72 on the radar gun and on the long shot i pulled away lol short track i just spin like no other!! though i have a 430 build too....good times
    Lewiston, N.Y.
    1,479
    If you took off like a bat outta hell and then she was keeping up with you and there was no smoke i would assume gearing like others have said. Do a compression test as suggested and see where she stands. You might be fine other than gearing which is a easy fix. Good luck!
    Oct 2009
    352
    Thanks for the tips guys,I'll check it out and see what size tire/gears and I think my father inlaw has a comp tester I could use.
    You need to do a leak down test (plenty of threads on here that explain it to you. . And like Raffa said, not even the slightest amount of play up-down , or left to right or it's time to split the cases.
    Don't do it if you feel uncomfortable with it of find a good buddy who is familiar with it to help. Even tearing it down requires brains and special tools; Good luck!!
