Thread: Suzuki ALT valve repair
    maxdallasfan's Avatar
    maxdallasfan is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    New Jersey
    381
    There is a guy on CL by me selling a Suzuki ALT185. Says the valve broke on it. Would this be a repair for a seasoned veteran, or could a rookie like myself possibly attempt it?
    Toaster556's Avatar
    Toaster556 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2010
    Fraiser Valley, BC, Canada
    176
    Easy with manual, but you're looking at a full top end and possibly a head replacement. The biggest problem is finding a piston for them, if you need a .25 or .75 over Sudco claims to have them. If your head is trash, DR/DRZ/LT/ALT125 heads will fit and bump the compression ratio a bit (They're 2cc smaller, so from 9.0:1 to 9.7:1), and they're cheap.
    Nov 2007
    ulysses pa
    1,231
    valves just dont break. something else happened to cause the broken valve. like the guy said above, a manual will help. you may be looking at more than just a valve replacement.
    New Jersey
    381
    Good point.
