Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 32
Thread: TRI Z cylinder
    Sep 2003
    21
    TRI Z cylinder
    Hi ive got an 86 tri z and the piston is goosed its deformed on the exhaust side, It looks to have left deposits on the cylinder. Is the tri z cylinder coated with nikasil or something similar or will i just be able to hone it. Also how do i know if the last piston fitted was oversize? it has 25 stamped on it.
    Thanks in advance
    Scott
    Dec 2002
    SW Alabama
    763
    The z cylinder is not plated. The 25 prolly means .25mm oversize.
    Trikes: Cagiva 200, 85? Tiger 250,(2)84 200x's , (3)86 200x's, 87 200x, (5)85 350x's, (2)86 350x's, (2)85 250r's, 86 Tecate, (3) 85 250sx's Restoring: 83 200x, 86 250sx. Too many utility trikes to list.
    Sep 2003
    21
    would this be the first oversize ? and how would i be able to check what piston id be able to fit to it next time ?
    Dec 2002
    SW Alabama
    763
    You can go to wiseco's site or denniskirk.com At dk just shop for tri-z pistions and they should show all the sizes. On the z I think the next size will be .50 mm.
    Whiteman
    mbg75 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2003
    Long Island
    256
    .25mm is .10" over, .50mm is .020" over..... etc
    Back on 2 wheels for now!
    clean 86 350x for sale.
    Sep 2003
    21
    So if th piston which was fitted was the first oversize and the bore doesnt look to clever. Am i best to go to the next over size ? do i just hone the bore till the rings fit? any help appreciated
    thanks
    Dec 2002
    SW Alabama
    763
    Have a shop measue your cyl. Then you will know if it needs to be bored. Usually they do need to be bored.
    Aug 2002
    NY
    2,652
    i personally have the clyinder bored. this way i only have to do it once. but thats just me. i never did a hone before so i dont know if its better. my yamaha warrior was low on compression and the machine shop said they could hone it. i had them bore it. this way i know everything is good. but do what you think is best
    Sep 2003
    21
    Thanks guys but i theyre arent any shops that i know of near me. I was kind of looking to do it myself. Is it possible to hone up to the next size ?
    Aug 2002
    691
    The only purpose in honing is when installing rings. This is to deglaze the clyinder where the rings will wear in right, otherwise they will not seal properly. Honing was never intended to be used as a way to go up to the next size bore. Honing that much you would never keep the bore straight or uniform.
    73 cr250m elsinore, 85 atc70, 85 250r flattracker, 87 250es bigred, 86 tecate, 2004 gas gas de300
    Tri-Z Pilot's Avatar
    Tri-Z Pilot is offline Check my feedback before buying from me Got the holeshot
    Central PA
    1,952
    Yeah, honing just fre up the cylinder, you can buy a honing attachment for a drill, but I would leave the cylinder boring to the professionals.
    Current Rides-Soon to be 85 350X, 84 200X
    PastRides
    86 250SX 85 Tri-Z (yellow) 85 Tri-Z (silver) 86 200x 01 Blaster 99 Blaster 85 ATC250R 86 ATC250ES 84 Tri-Zinger 60 ATC500R Project
    Originally Posted by atctim
    I prefer to be called a "3 wheeled American" I find the term "Trike People" very offensive and derogatory!
    SOON MY PRECIOUS!
    Dec 2003
    83
    :o take it too a machine shop
    Owner of:
    85 125M
    01 Polaris Scrambler 500 2x4
    74 Honda Trail 70
    Aug 2002
    691
    The best hones are the ball type hones. They work far better and do a more consistent job than the ones with the three fingers on springs like they sell at autojunk, etc. Btw, JW125M that's not very good advice to be giving people. You and your dad may have pulled off a honing to the next bore, if you had some sort of jig, such as a machine shop would, but for what it costs to have a cylinder bored, it is pretty stupid to buy a new piston, and then ruin it and another bore, because you cheaped out. A hone is not meant to make bores with, and there is no way that someone with a hand drill can go all the way up a piston size, without ovaling or egging out the bore.
    potsdam NY (upstate)
    1,437
    yeah i know it cost what like 25 $(atleast up here) to get a shop to bore a cylinder out for you lol cheap people amaze me some times doing trailprotrailprotrailprotrailpro half assed all the time and then wonder why there bike runs like trailprotrailprotrailprotrailpro or blows up.
    looking for a TRI-Z 250 to restore at the moment
    LONG LIVE THE 2 STROKES !!!
    Dec 2003
    83
    Owner of:
    85 125M
    74 Honda Trail 70
