Thread: 200e no go
    Dec 2012
    iowa
    3
    200e no go
    Had a guy bring me a 200e to work on the other day.You can put it into gear and it does nothing. no noises,or anything and if you lift the rear tires they will roll slowly but it does nothing if there is weight on it.I also noticed if you put it in gear not running it rolls just like its not in gear.before i dig into this thing just look'n for advise on where to start? rear end, drive shaft, tranny or clutch
    Oct 2012
    Ontario, Canada searchmont
    7
    you could try the secondary clutch adjuster on the right first if that dosent work it might be the primary clutch or some thing on the shifter rod and i beond that i have no idea how to fix the clutchs or the shifter rod i just no whats in there from taking apart a trashed engine to see whats in there
    84' 200es bigred 80'ish yamaha dt or xt bike frrame with honda 200cc welded in 84' bombardier-skidoo alpine 640er (runs great but still needs lots of work to make it awesome again)
    Howdy's Avatar
    Celina, Ohio
    10,079
    Cutch or sub tranny would be the things I check out first.
    Howdy
    Pacific NW
    4,255
    what model and year again?
    I've had the sub trans slip in between gears and it will go no where,
    if that's what model it is.
    service manual
    ps - just a joke to lighten the mood.
    no go?
    Honestly that's why they couldn't sell the chevy nova in Mexico.
    You'd think the marketing people whould've checked that.
    Oct 2012
    Upstate NY USA
    118
    Quote Originally Posted by tri again View Post
    service manual
    no go?
    I'm not understanding what you've said...
    Thanks,
    Chris
    84 125m
    83 185s
    83 185s
    83 185s
    84 200es
    MN
    3,263
    I think he meant the sub trans, hi/low, they sometimes jump inbetween gears and so are in a false neutral. But he said lifting the rear end the tires will turn, but putting a load on them they won't, so i suspect its the clutch. Try adjusting it first, if that doesn't work then its time to tear into the right side and replace parts.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
