Results 1 to 3 of 3
Thread: ATC 90 110 crank swap
    May 2012
    Grand Forks, ND
    6
    I have a 78 atc 90 and I've heard that I can take the crank from a 80-82 110 and it will bolt in with no mods, I've read about people doing this. I believe the 110 and 90 used the same wrist pin and had the same length con rod correct? I've heard conflicting things on forums about this subject.
    Jan 2011
    Brazil, Indiana
    2,087
    I think the 110 uses a 15mm wrist pin
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    6,807
    NO its not a direct swap and lots of mods needed to do the swap , If your looking for a bolt in stroker crank give me a PM .
