First off, the pic have to be under 98KB, then they have to be in the right format (i know for sure that Jpeg works, not sure what else does) once you got that right, then twards the bottom above submit click on add an attachment and then it will come back to this screen but twards the bottom you will see a small box with browes next to it and below it will be a bigger box with add attatchment next to it. click browse and find your picture then click ok. it will come back to this screen again, then click add attatchment, it will agian come back to this screen then click submit. that should do it. you have to have your message typed in before you can do it though.
85 Tri-z
38mm Flatslide
Boysen Power Reeds
DG Pipe and Silencer
Bored 1.25mm over
Wiesco Pistion and Rings
K&N Clamp on Filter
Compleating Restoration
