Results 1 to 15 of 16
Thread: 86' 200x needs rings??
    Maine
    73
    hey ya'll, my 1986 200x was rebuild by a honda shop in 2006, new high comp. wiesco piston, bored .040" over (66mm). it hasnt been ridden a whole hell of alot since then, maybe 15-20hours since rebuild, but the last few times i rode it i noticed it would start hard once it was hot (like low compression) and then the last time i was riding it i noticed the oil was low and it was smoking once it got hot. since then i re-filled the oil, and it smokes the entire time its running. Does this sound like it needs a new set of rings and gaskets, or is this a valve/head problem? any imput would be great, i just want to check all my options before i tear into it. Thanks and Merry Christmas!!!
    TRIKES....BADDD ASSS BIKES!!
    1986 200x
    1995 300ex
    2000 400ex
    1989 CR80
    1996 CR 250R
    1997 XR 70
    1977 YAMAHA XS500
    1989 KITTY CAT
    Dec 2010
    Pennsylvania
    510
    so is this before or after the rebuild?
    Kentucky
    511
    I wouldn't think it was the rings with that little run time and the first time you run it it didn't use oil or smoke so your rings did get seated. If you didn't do a valve job on the head while you had it down I would think the head was what was wrong.
    Maine
    73
    well thats what i was thinking, it couldnt be the rings right? like i said i havent ridden it a whole lot since rebuild, even though its been several years. The head/valves were NOT touched during the rebuild, just piston, rings, cylinder bored, gaskets....think that was it. it ovbiously burned up some oil (hence the smoke) cause it was just below the stick when i noticed something was wrong. i dont have my compression release hooked up, could there be an issue with that being stuck?? not sure how that mecinism operates.....
    1986 200x
    1995 300ex
    2000 400ex
    1989 CR80
    1996 CR 250R
    1997 XR 70
    1977 YAMAHA XS500
    1989 KITTY CAT
    6,811
    Not sure why but I have see allot of wiseco rings go bad prematurely , its like they just loose their spring tension . Rig gaps all seem ok but not seating to the cylinder anymore . I would pull it apart and check it out before it does any harm to the cylinder .
    I have strayed away from using wiseco pistons in my shop because its not good business having a motor last one season and trying to explain to customers that wiseco rings just suck .
    Maine
    73
    hmm interesting. any threads on here about valve jobs? while ive got the head off i might as well do those.
    1986 200x
    1995 300ex
    2000 400ex
    1989 CR80
    1996 CR 250R
    1997 XR 70
    1977 YAMAHA XS500
    1989 KITTY CAT
    Dec 2009
    illinois
    1,765
    It sounds like the rings did not seat well or your Honda mechanic done a poor job boring the cylinder. Low compression with smoke means your rings are bad or they did not seat well. I never had luck with bore jobs myself and they never seemed to last long but that's just me. If you had good compression and it still smoked then that would mean your valve seals are bad but in your case it is the rings/cylinder. There are 2 routes you can go, first you can just buy new rings and gaskets and valve seals which would do the basic overhaul but you could still have a bad bore and it would do no good. Shortline has mentioned wiseco rings go bad prematurley and I have witnessed this myself so it could very well be the case. It might be a good idea to have your cylinder inspected by a certified Honda Mechanic before you do the new basic overhaul.
    Kentucky
    511
    I havn't heard that about wiseco. What pistons do you use? I've got a 12:1 wiseco in mine and have ran it pretty hard with no problems yet. You got me worried now.
    Maine
    73
    ill look back to see if ive got any paperwork on the piston. i bought the 66mm weisco, think it was 11.5:1?? maybe it was the 12
    1986 200x
    1995 300ex
    2000 400ex
    1989 CR80
    1996 CR 250R
    1997 XR 70
    1977 YAMAHA XS500
    1989 KITTY CAT
    MN
    3,263
    I remember a few years back a friend of mine rebuilt his using Wiseco piston and rings and the rings were crap after a week, took it back apart and honed it again and put in a stock piston and new rings from Dr ATV and it was good to go, that was three years ago at least and it still hasnt had an issue since.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Maine
    73
    is there a different set of rings i can buy for that piston? or do i have to use wiesco rings...
    1986 200x
    1995 300ex
    2000 400ex
    1989 CR80
    1996 CR 250R
    1997 XR 70
    1977 YAMAHA XS500
    1989 KITTY CAT
    NEPA
    7,051
    Only Wiseco will fit. To answer/troubleshoot your original ?. All you do is remove the breather hose from the case. If there is smoke there,it's cylinder seal. If it's a head problem,which yours is not. The smoke will be contained within the combustion chamber and will not make it past the rings to the case. Since I've been able to remember,alot around here,mainly dealers who wanted to sell oem. Have been badmouthing Wiseco. I personally have had nothing but great luck. But also take Mike 100% at his word,and do not doubt a bit there could be problems. At any rate,,unless YOU ran that thing low on oil and cooked it,,and I am NOT saying you did. That dealer owes you a resolution. After this long you'll have to eat something,,but they should be willing to do what is right. All the labor at least.
    Maine
    73
    i dont think i cooked it....changed the oil once a year since rebuild, and didnt notice it getting hot at all. it also didnt take much, maybe half a quart to get it to full level on dipstick. i highly doubt the dealer will work with me at all....even though i spent almost $600 on this engine build, it was 6 years ago..
    guess ill do some compression test here soon, get some readings while its cold and then once its warmed up. that should tell me something
    1986 200x
    1995 300ex
    2000 400ex
    1989 CR80
    1996 CR 250R
    1997 XR 70
    1977 YAMAHA XS500
    1989 KITTY CAT
    jmax857's Avatar
    jmax857 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    bancroft canada
    354
    Did you have it bored or was it bored previously and he put a .040 piston in it. Its possible your cylinder is oval if it wzsnt a fresh bore job.
    Tear it down and let them measure it, IN FRONT of you. They could have easily given it too much clearance (don't forget that cast or forged pistons determine that amount) and ask "what gives??" Could be a bad hone job too; Again, did a professional bore and hone this??
    Your DC is not the issue, many guys don't run them until they snap the kicker off.
    We have 25 year old OEM pistons still on the 1st bore running well out there.
    I've seen mixed up rings, too much end gap rings and upside down rings.
    I've also seen oil rings stuck or staggered wrong.
    That 86 motor does not like 12:1, 10.5 with a pipe will be just fine.......
