A good suggestion would be to get a shop manual. Also, your initial posting was very vague. You should be running the trike with an air filter. The 2 stroke engine is way more tempermental than a 4 stroke. No idea if you are premixing your fuel or using the factory oil injection. No idea about all the basics of the engine. Clean carb, properly lubed and set throttle cable, engine compression, sparkplug cleanliness, airfilter cleanliness, etc. You need to provide alot more info to able to get a better idea of what you have going on. Not trying to be mean, just saying.
Nicholson 500x (Project)
Nicholson 185s
PK Racing Suspension 70
A+ Inc Suspension 70
AWS Aluminum 90 frame
