Results 1 to 2 of 2
Thread: Differences between 81 and 83 185S frames?
    Scootertrash's Avatar
    In the sticks
    4,638
    Are 81 and 83 185S frames identical? A buddy has an 83 1856S that's had the frame welded rather sloppily, and he has a 81 185S frame I told him he should swap them out, but he says someone told him they aren't the same. Are they? Will the 83 suspended front forks fit the steering head on the 81 frame?
    Thanks!
    Miami,Fla.(305)
    808
    Yes -it will go on the same. the only concern is the airbox will also have to be swapped & it would then draw air to the box from under the seat (insteqd of at the neck and thru the frame)-which is not as good in mud/water
    Previously Owned:
    1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
    1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
    1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    1969 HONDA MINI TRAIL 50
    TRIKELESS
