i am in the processes of putting the rear brakes back on my triz and i find out that my caliper and caliper mount WONT LINE up its off like 1/8 inch
plz help!
Thanks
plz help!
Thanks
theres no way the holes cant line up. :? are you putting it on the right way? and is it the right caliper?
1985 YAMAHA TRI-Z 250 sold
2006 YFZ 450
could someone post a pic of the correct brakes so i could tell if i have the wrong caliper
thanks
do you have the front caliper? look at that the rear and front caliper are the same, you can put either one on the front or back.
2006 YFZ 450
well man the rear caliper is bigger than the front but its the same style i know its the caliper that came off the back b/c i know i had to tap the bolt hole to get a bolt in their maybe it isnt the right one some one had the wroung one on their and cross threaded the bolt to get it to stay so they could ride ?
:evil:
my 2 calipers on my Z are the same size.
2006 YFZ 450
Yep, the calipers should be the same.
Trikes: Cagiva 200, 85? Tiger 250,(2)84 200x's , (3)86 200x's, 87 200x, (5)85 350x's, (2)86 350x's, (2)85 250r's, 86 Tecate, (3) 85 250sx's Restoring: 83 200x, 86 250sx. Too many utility trikes to list.
maybe you have a 87-89 banshee front caliper(which look the same),or you dont have the stock bearing carrier maybe a banshee one????? :?
