I am trying to get my head lights to work.....I am using a 350x headlight on a 85 250r, and as soon as I turn on the lights the bulbs burn out.....I am getting 26.4 vac to both the high and low hot leads at idle, there is no direct short to either lead untill I turn on the switch...each lead shows a short to ground when the switch is on and switched to its perspective high/low position....is this a regulator problem or a switch issue or both....any help would be great.
Thanks,
Jeff
