O Well I Guess it's time. Been gathering parts for over a year now. I'm am no expert, but kind of know what I'm doing. Thank you members who have built similar builds and posted them here in the past for I am basically following in your footsteps. With most of the hurdles out the way this build should not be dragged out too long, but be patient I still have some i's to dot and T's to cross. For an appetizer Here's the motor. Picked it up in running condition. Didn't even smoke. I polished most the case up to 2000 grit. Replaced it's tight low hour 54mm crank sl90 converted tranny. After scouring the web I've managed to score all I need for the manual clutch conversion. Most of it Wound up being NOS. New discs and springs especially. Now for the top end, the piston rings and cylinder were in great shape so I honed it alittle blasted it and gave it a nice high heat paint job and baked it to cure properly. Oh forgot to mention piston is 54mm domed high compression. Not sure the make or ratio but think the original owner said 11:1 or 12:1. To finish the top end I'll run one of the three aftermarket cams I've got. One mild and two 3/4 racing cams. Not to mention a light port and polished exhaust port and slightly opened intake port to match the pk intake. So there's the motor. Stay tuned. Same three wheel time. Same three wheel channel. I've still got a small wish list to fill which Maybe some of you can help with and probably some guidance. Thanks for looking. Criticism and tips welcome.P.S. and Yes it got new bearings, seals, gaskets, valves, and heavy duty valve springs. When I do something I try and do it right. With bore and stroke it's 125cc.
