Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
Thread: Neato Bandito Stroke Me Build!
    Pekin IL
    529
    Beautiful!!!! Those us90 fenders look tuff!
    1985 250r
    1985 200s
    1984 200x
    bandito x2
    1979 atc70
    Trikefest 2012,13,14,15
    San Marcos Ca.
    716
    Awesome trike!!!!!!! I to would like to know more about the polish work to the cases. Looks great.
    Apr 2012
    Hampstead, Maryland
    65
    Thanks for the compliments. The way I polished the cases was simple, but took some time and elbow grease. I started with 320 grit sand paper sanding in one direction as much as possible. Wet sanding makes the paper last longer. So after 320 is 400, 600, 800, 1000, 1500, and 2000 grit. Hit it with some aluminum Polish paste and Boom!.Here's a couple more pics of the case.Click image for larger version.
ID:	182856Click image for larger version.
    85 Honda atc 110 RIP
    85 Honda atc 110 daily rider
    84 Honda atc 125m
    78 90/125 chrome bandito winter project
    C.J is offline Just Too Addicted Arm chair racerJust too addicted
    Central, Louisiana
    639
    Wow that's a beautiful machine!!
    If you don't mind me asking, how did you have your front axle made? That's the biggest thing holding my build up is I need a front axle that fits my forks
    too many bikes to count. too little time on hand.
    San Marcos Ca.
    716
    Again nice job. Thanks for the info.
    Apr 2012
    Hampstead, Maryland
    65
    Quote Originally Posted by C.J View Post
    Thanks... I had an axle made by a friend who works in a machine shop. I have to drill out my forks to fit yet.
    84 Honda atc 125m
    Central, Louisiana
    639
    Ah ok. Did you get it made to fit the 110 bearings? I have no qualm (did I use qualm right?) about drilling out my forks even though they are old Suzuki pieces. That would probably be the best route to go so it doesn't have to have a couple different step down to it
    Apr 2012
    Hampstead, Maryland
    65
    Yup. Used the 3x100 hub. It's axle is thicker than the 4x130.
    84 Honda atc 125m
    Central, Louisiana
    639
    Ok AWESOME! Thank you very much! Now i know: 1) why that first bearing set i got had bearings that were too small for my axle, and 2) what to do for the axle I need!
    Thanks a ton for the help!! Maybe my lil white Nik will be coming together finally!
    Feb 2006
    EC
    1,607
    Holy hell, that's badass to the bone! Very nice build, man! I never like that kinda handle bar on a motorcycle, but they really look slick on there, very nice!!
    Mar 2007
    Texas
    5,045
    Very nice build. I am thinking of doing a custom jobber form ground up using a modern pit bike frame as a design base and a 140-180cc engine.
    first I have too many project ahead of it, so for now it stays in the brain.
    ________________
    https://www.mikesatvfix.com
