Results 1 to 3 of 3
Thread: 200x cylinder to piston clearnace
    Dec 2012
    Buckeye
    13
    I have a200x that was smoking bad when revving the throttle. White smoke, oily plug.
    So I am replacing the rings.
    The cyliner measures 64.8 mm
    The piston measures 64.3 mm
    Is that normal clearance or do I need a new piston?
    Dec 2012
    missouri
    62
    You cant make one measurment and call that good...you must measure from top to bottom of cylinder in several different places with proper measuring tools.
    Slidell, LA
    4,738
    are you using a bore gauge or a micrometer? If you are using a micrometer, your measurements will be inaccurate. You will be money ahead to just take it to a shop and get it professionally done.
    Stock bore on the 200x cylinder is: 64.990-65.000MM, service limit is 65.100MM
    Stock Piston O.D. is: 64.962 - 64.982MM
    so if yours is still smoking, there is no way you are within specifications. Take it to a shop.
