Page 1 of 28 1 2 3 11 ... LastLast
Results 1 to 15 of 413
Thread: TecateDan and Fabio's joint 500 effort
    Affectionately known as "The Green Monsta" (After the elevated highway that no longer exists in Boston, not the wall at Fenway Park) this bike will be based on a first-gen Tecate. We've got a 1986 KX 500 power plant we're using.
    Making the square tubing bender-
    It's not much yet, but it's a start. I'll have Dan post some better pics of the jigs.
    Mexico
    9,020
    Are you replacing the stock down tubes with the squares? Same engine you were needing a left case for? In-frame pipe? MUST HAVE INFO!!!
    blackstone/ma
    1,491
    I tried to make one that would make a 180 with a 3.875" radius. The small jig but when I tried to bend with it it just ruined the pipe. May have been the Jigs fault may have been the structural limit of the tube?? not sure. When Fab got here we built the larger bender with a 7" radius and made some 65 degree bends to match the old down tube angle
    Springfield Mo
    3,309
    Looking good men, can't wait to shred on it at Trikefest!
    RIP Ninja!
    Trike Fest 2011, 2012 Vet!
    Trikes Currently Owned:
    87 Big Red 250es
    83 Honda 200s
    81 Honda Atc 70
    (4) Suzuki ALT 50's
    Yamaha YT 60
    Yes, yes, and yes.
    blackstone/ma
    1,491
    This way I can just out run you casue last time I tried fighting you it took my rib 4 weeks to heal
    Quote Originally Posted by thestud25 View Post
    Mexico
    9,020
    Quote Originally Posted by TecateDan View Post
    Stuffing the tube with sand and capping the ends might help a little, but no matter how good a setup you have squares always deform on the inner radius. The thinner the wall the worse it is.
    Just a couple of pics of what Dan did this weekend.
    Gold Hill, OR
    1,295
    Very ambitious build guys! I can't wait to see more progress. Does the kicker clear the frame like an 86-7?? You guys gonna cut up a KX500 pipe or hand built? I could ask a hundred questions but I like the element of surprise lol. Hey, that compression release looks familiar! You were right, it does work good!
    Joker 90
    1981 Yamaha YT125
    1986 Yamaha Big Wheel 80
    1986 Kawasaki Tecate KXT500
    1987 Kawasaki KXT250B2
    2005 Yamaha YFZ450
    Ontario, CANADA
    4,538
    AWESOME! cant wait to see it done! very cool guys
    RPFLU member and co-owner.
    Hardtails is all we do.
    #NOLINK
    #MAKEHARDTAILSGREATAGAIN
    #SUSPENDTHIS
    The kicker should be fine EZ. I've got a modded Tecate kick start lever that goes onto the lower part of the KX kicker. It'll be the length of of the regular Tecate kicker. The compression release is key to starting it with the shorter lever. Without the compression release, the Tecate lever would never be enough to start this engine.
    We're not sure what we're doing with the pipe yet, but we want something nice. That much we know.
    If you or Johnny need some diamond plate I have some plain steel, plain aluminum and chromed aluminum. .125 thick
    Speedy Metals always treats me well with drill rod, plain steel DOM tubing, etc etc etc.
    STL
    3,560
    Updates!? I like where this is headed
    Dan and I are going to convene tomorrow in the a.m. to throw some wrenches around. Thanks for asking.
    Carthage NY 250r rules
    2,355
    Cant wait to see what you guys come up with.Love 500 builds ,a friend of mine had a kx 500 that thing was an animal .Good luck with the build.
    250r rules
