Results 1 to 15 of 23
Thread: 1985 Honda 350X Frame Questions
    Feb 2003
    New York
    623
    Here are some pics of things I noticed on this 1985 Honda 350X I recently bought. Tell me if you think the frame has been welded.
    See the pics.
    Does it look like the fork is too far at the end of the axle ?
    When I went to loosen the the 4 nuts that hold the axle I noticed one of the studs is broken. When I slid the fork off the studs
    I felt the fork pop out toward me.
    Attached Thumbnails Attached Thumbnails SDC11463.jpg   SDC11465.jpg   SDC11451.jpg   SDC11439.jpg   SDC11452.jpg
    ♠ 58 ♠
    Ride 3
    To me it does appear welded.
    Apr 2006
    SE CA Dez in the sandbox
    893
    Ditto, that's not typical
    fingerlakesny
    2,834
    just take the fork and twist it till it is ligned back-up with the axle... = the forks are tweaked a bit....
    250r dust runner
    Feb 2003
    New York
    623
    It looks funky up at the neck of the frame. God knows what happened. Looks like a head on wreck.
    ♠ 58 ♠
    Ride 3
    Feb 2003
    New York
    623
    more pix
    here are some more pics
    It was a choice between a 1986 200X or 1985 350X
    Both bikes were 1200
    Attached Thumbnails Attached Thumbnails SDC11450.jpg   SDC11453.jpg   SDC11457.jpg   SDC11458.jpg
    ♠ 58 ♠
    Ride 3
    fingerlakesny
    2,834
    nice looking trike.. i think its factory weld... the paint is still intact and the rest of it has been taken care of... but thats me...
    250r dust runner
    Feb 2003
    New York
    623
    Never saw a factory weld at the neck like that and that's whats weird your right it is the original paint on top of that weld at the neck, but then again I am not an expert.
    Some minor fixins and she should be good to go.
    Whats baffling about the deal was most of the bike was well taken care of so how come the frame took such a blow where it needs to be welded ? Very odd. If these trikes could talk I bet we would have amazing stories.
    The frame is JH3TE 0809 FM016477
    Motor is TE08E-5016600
    ♠ 58 ♠
    Ride 3
    Quote Originally Posted by 124356q View Post
    This is the second time I've seen you tell somebody to turn the fork until it lines up and I corrected you last time. If you want to hack on your own junk on your time, that's fine. Please refrain from spreading bad advise in these forums though. The fork is bent, plain and simple. You can sit there and spin it until your little heart's content, but it's still going to be bent.
    Sweetip, I can tell just from the last pic in post #6 that your forks are bent, or at least one of them is. You have two choices. You can get it straightened or you can replace it. If you want to take the hack's advise you can spin it so the bend is in a different place but guess what? It will still be bent.
    I've posted this before.
    Lift up the trike so the tire is off the ground an inch.
    Loosen all 8-12mm bolts (u can leave them in there)
    Try to rotate a tube, if it does not, gently place some tool of your choice to SLIGHTLY spread the 4 pinch points.
    Now, it will spin. Spin each upper tube with your hand and watch down below. You will see the front end moving around.
    Andy, you know I don't mind helping you but you seem to like "change"
    I built and rebuilt a 350X after you drove 5 hours to get here, attack it in one day and rebuilt it the next. I enjoyed helping you and having you stay but no way I can do that again; Far too busy.
    Those were 2 LONG days and you left my yard with a pretty well (everything rebuilt or repaired) 350X; And then you sold that perfectly running 350X.
    So now you buy another 350X that probably needs quite a bit of work and those frames don't break there unless bolts are missing. There is a 100 lb motor in there.
    Dec 2010
    Back in VA baby!!
    711
    No way those welds are factory, not to mention your rear end doesn't appear to be tracking right either...find yourself a good frame if you can...should run you 100 or so, well worth it...the 86 frames are a little more stout if you can find them, but you'll also need the 86 motor mounts (bolts are larger), and then gusset up the weak points. Your forks are indeed bent...it'll be cheaper to take them to a reputable shop and have them straightened. Buy some new seals and rebuild them while you're at it, chances are they'll need it if they've been bent like that.
    Feb 2003
    New York
    623
    Well thanks for the advice. I will get the forks straightened out and just ride the bike as is.
    I am not looking to jump or do any really hard riding. I just wanted to get your feedback because I wasn't quite sure. I will keep an eye out for another frame. And hey Steve no hard feelings. I paid you for your time and appreciate all the work you did on the previous 350X.
    Andy, That front axle is sunk in too far. You may have a collar issue or when those forks were (reinstalled) the bent went outwards and thats why it's buried.
    None of my 350X's have that issue. #1 post, pics 3 and 4.
    Jun 2009
    Tunkhannock,Pa
    904
    i dont know if i would ride it with that axle like that even if you dont plan on any hard riding it doesnt seem safe just my opinion
    1985 200X
    66mm H&S Piston
    Little Bit Bigger Cam
    Bassani Exhaust
    1985 350X With Bassani Exhaust
    1983 Honda 200E (PARTING OUT!!!!)
    1985 Yamaha Tri-Zinger
    My Feedback Threadhttp://http://www.3wheelerworld.com/showthread.php?105185-Feedback-for-RodKnockRacing&highlight=RodKnockRacing
    Feb 2003
    New York
    623
    Hey Steve,
    I am going to have the front end checked out and see how much the labor cost is to repair the damage (if it can be repaired). Then compare that to the cost of a rebuilt front end. Also have them take a look at that axle collar as well. And that other guy who mentioned about the rear tracking is right. I noticed the same thing. Oddly enough these paddle tires are made for sand and mud depending on how they are mounted.
    I am going to a local Yamaha dealer and I do trust the work they do but the labor rates are insane at 90 per hour. I might be better off buying a complete different set of front forks and different axle collar. That is pretty much the extent of anything major I saw besides the front brakes and frame. I will do this a little bit at a time until its worthy to ride. I just want to make sure the bike is safe to ride before I down on the throttle. BTW thanks for the heads up from Aldo and everyone else. Much appreciated !!
    ♠ 58 ♠
    Ride 3
