Results 1 to 12 of 12
Thread: 1984 Honda ATC 125M Backwards shift pattern??? PLEASE HELP!
    Dec 2012
    Temperanceville, VA
    197
    OK here goes...I purchased a 1984 atc 125 m last week, great shape, runs great..only thing Im having an issue with is the shift pattern. You shift down to up shift thru all the gears and up to downshift thru all the gears. It has the high/low range 4 speed trans. I grew up on a 86 trx honda 70 with the 4 speed and it was the other way around. Is this something with the hi/low transmissions or is something really screwed up in the trans. I have owned many Honda 3wheelers and this one has me puzzled! Thanks for any info on this model!
    Nov 2010
    Oshawa, On, Canada
    2,123
    Nope, that is just how the 125m is. Its perfectly fine.
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    Blossvale NY
    4,563
    Perfectly normal. Some of the old ATC's had an upward shift patter, others had downward. The 125m was a downward shift pattern,
    If it goes though the gears and the hi-lo sub trans works your trike is A-OK...
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    Dec 2012
    Temperanceville, VA
    197
    Thanks for the info Jason and Ride-Red
    Pacific NW
    4,255
    yeah, I've gotten into trouble jumping from one trike to the next with defferent shift patterns.
    The only thing more absurd is the old european / british bikes had the shifter
    where the brake is back inthe 70's.
    Yupp, go to gently touch the 'brake' and Downshift at 60mph is never good
    when yer not expecting it.
    Have fun and be careful.
    Dec 2012
    Winnipeg
    74
    My '84 110 is the exact same way. I thought it was going to be weird to get used to, having grown up on an '85 trx250 which is the opposite, but it was like swimming, you never forget. Mind you i did a little research first, and knew that the shift pattern would be different, so there ya go eh.
    MN
    3,263
    Try going back and forth between my 84 200ES which is down to upshift, and then the 85 125M a friend has that is up to upshift. The 85 and i think later years of 125 went up, the earlier years all seemed to go down. Why they didn't just keep them all the same is beyond me.
    1984 Honda ATC200ES "Big Red"
    1982 ATC200E "Hondie"
    Howdy's Avatar
    Celina, Ohio
    10,079
    I had a 200x that shifter side to side one time ( right after a crash ). But that is another story all together. LOL
    Yep, different machines shift up and others shift down. It will become 2nd nature after awhile. Then you will hop on another machine and have to re-learn to shift for a different pattern. LOL
    Howdy
    Dec 2014
    PA
    12
    my 110 is all up
    Oct 2014
    Central Florida, USA
    53
    I believe '84 was the cutoff. My '74 CT70, '81 ATC185/200, and '84 ATC70 are all "down is up" shifting, and everything I've ridden '85 and later have been "up is up" shifting. Definitely throws you going back and forth sometimes. My dad worked at the local Honda dealership in the '80s and early '90s, he mentioned some of the racing trike guys bringing in their '85 and later models to get the '84 and earlier transmission setup installed, as they felt it was easier to shift "down" to get going on the track.
    Jan 2014
    La
    1,062
    yea perfectly ok all of our bikes besides my 86 125m shift down to get into gear. I learned to ride with the down shift so i think the up shift is backwards.
    Aug 2015
    Chatham Ontario
    Pretty sure it's all 1984 bikes that are downshift.
