Thread: 1983 110 atc no fire
    Jan 2013
    mo
    help ! i cannot figure out why i have no fire at spark plug , new plug .new coil, new cdi box . no broke wires , impulse at cdi breaker . 1volt at alternator while pulling rope . any ideas?
    Cornholio's Avatar
    Cornholio is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2012
    Staples Minnesota
    180
    spark plug wire... And, you shouldnt have fire, you should have spark. Depends on how you are testing the plug, set it on the engine then pull it over, make sure the plug is grounding out on something
    Life is short, Party naked!
    1986 250r
    1984 200s
    1984 250r
    1970 us90
    1991 Yamaha Blaster
    1984 110
    1985 110
    1984 200x
    Jan 2013
    mo
    thanks but have done that and tested with meter ,still no fire . is there an inline fuse somewhere? am i missing something?
    Cornholio's Avatar
    Aug 2012
    Staples Minnesota
    180
    make sure that your switch and connections to ground are good. to test if the swtich is bad, unplug the 2 wires from the switch, then plug the one from the coil directly to the stator wire i believe...
    1986 250r
    1984 200s
    1984 250r
    1970 us90
    1991 Yamaha Blaster
    1984 110
    1985 110
    1984 200x
