i have a 1980 atc185 and im looking for an airbox that will just bolt on
what years fit the 1980 atc185
thank you
tom
thank you
tom
The reason my bike has no reverse is because nothing can stop it
I think that the 80-83 185's would be very similar, try parts fish.com to be sure.
If you have trouble finding one Dennis Kirk does sell the K&N kits that are made to replace the factory airbox, problem is you loose the water resistance of the stock setup and may have to mess around with your carb mixture a bit.
Hope this helps some
Why get a whole air box? Im planning on just buying a clamp on UNI filter for my 185s. They are easier to clean and you don't have to put up with bruised knuckles trying to put those rubber tubes back on.
Chris (Reno,Nevada.)
67 Honda CT-90
75 Honda ST-90
81 Honda 250r
85 Honda 250es BigRed
99 Honda XR250R
04 Honda CRF150F - Cousins Ride
Sorry, the '81-'83 airbox is different. If they were the same then I would sell you mine.
-Andrew
2004 BMW R1150R
1972 Honda CT 70
2007 Lifan 110
The 1981 and 1982 ATC185S have the same airbox, the 1983 ATC185S has a different airbox. You can also use an ATC200 airbox(not200S/ES/M or etc).
84 ATC200X--Wife rode it once, now I can't get it back.
84 ATC250R--Trying to find piston for 300R kit.![]()
85 ATC350X--Project finally under way, slow progress. For pics: http://groups.msn.com/ATCfriends/350xproject.msnw
84 ATC200S--Freebie from a neighbor, needs topend rebuild and tires.
