Results 1 to 8 of 8
Thread: Big Red Looses Power? Help!
    Oct 2012
    The other day i went riding in deeper snow with my 1983 200e big red, When i hit deep snow i hit the throttle hard and went real slow but was making it thru.Then my bike lost power and stalled. After that it did not start and so i left it for about 10 mins or so and came back to it and it finally started. I went riding again and I was going up a hill and the bike stalled at the top and the when it did start it had no power at all and was just rolling when i hit the gas it bogged down and almost died. The next time it stalled i Shook the bike back and forth a lot and the bike started up and it had power again and i didnt have a problem the rest of the day. I think that it is the float getting stuck and not allowing the bike to run right. Let me know what you guy's thing and what i should do?
    Oct 2011
    Lilly PA
    601
    I would deff say its fuel related. I would pull the carb and clean it and check your float level and try it. Let us know how it works for ya.
    86 Tri-Z
    86 Honda 250R,
    84 Tecate
    Cornholio's Avatar
    Cornholio is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2012
    Staples Minnesota
    180
    Does it backfire at all when before it dies?
    Life is short, Party naked!
    1986 250r
    1984 200s
    1984 250r
    1970 us90
    1991 Yamaha Blaster
    1984 110
    1985 110
    1984 200x
    Oct 2008
    NB, Canada
    852
    I'd say for sure it's a fuel problem. Gas isn't getting into the carb bowl fast enough. It could be the float sticking or not adjusted right, the gas cap not venting, or the fuel screen inside the tank partially plugged.
    Edit: I thought of one other thing, you could have a valve sticking when the motor get's hot. Which would result in a pop like Cornholio asked (I'm guessing he was thinking valve), and you'd have no compression until the motor cooled.
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    Always Hoping For a Maritime Trikefest- http://www.3wheelerworld.com/showthr...s-where-you-at
    "Wear Limits Are Just A Suggestion"
    Oct 2012
    When i start the bike it backfires a lot but not loud, so not sure if that is related to carb
    NEPA
    7,051
    You simply need to clean/strain all the fuel in your tank. Clean the tank and strainer,take off your carb,clean it. Put an in line filter in your line. And you should be good to go.
    Oct 2012
    I ended up cleaning the carb and it fixed it
    Southern MN
    1,875
    8.5 months later! Well, better later than never!
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
