Results 1 to 2 of 2
Thread: 1985 200x
    Jan 2013
    Florida
    4
    1985 200x
    Hey guy's just looking for a little info I could not find in the forum.I have been working on dialing my carb in on my 200x.My question is does the pilot jet supposed to have a rubber o ring?Because my original carb does not nor does my chines carb.Any help would be appreciated.
    Jan 2013
    Florida
    4
    Never mind I found my answer!The pilot screw is supposed to have a small rubber o ring.I think that was my problem with my poppy idle.I think some people get confused with the mid jet and the pilot screw. Because when they talk about adjusting the pilot ''jet'' or cleaning the jet they must be referring to the pinhole that the pilot screw screw's into.If your having an idle issue the mid jet should have nothing to do with it until you are about 1/4 or over into the throttle then the mid jet comes into play.I was having a really hard time getting my 85 200x to idle but after a new jet kit and lot's of reading I think I have it figured out.I will update with new info in a few days.
