Results 1 to 12 of 12
Thread: After the polish...
    slippy4 is offline Just Too Addicted Arm chair racerJust too addicted
    May 2003
    556
    After the polish...
    is there anything i should put on as far as clearcoat or anything to keep the metal from rusting or anything like that? or does the polish keep it from doing that? thanks
    85 Tri-z
    38mm Flatslide
    Boysen Power Reeds
    DG Pipe and Silencer
    Bored 1.25mm over
    Wiesco Pistion and Rings
    K&N Clamp on Filter
    Compleating Restoration
    Mar 2003
    NJ
    911
    depends what you polished.
    aluminum gets a little nasty and you have to keep polishing it with mothers aluminum polish or something similar. my zx7r has a polished frame. it is definitely something you have to keep up with otherwise it starts to look nasty. it looks great though.
    if you stripped the paint off steel, then you definitely need something to coat it or it will rust. bare steel rusts fast, unless you live in arizona or something. here in new york if you leave bare steal overnight it will rust. it needs paint or some other type of coating.
    86 KXT250B1 (4)
    87 KXT250B2
    85 ATC250R
    85 ATC350X
    84 ATC200S
    87 Banshee
    96 ZX7R
    May 2003
    556
    yes, i figured that, but what can i use?
    85 Tri-z
    38mm Flatslide
    Boysen Power Reeds
    Bored 1.25mm over
    K&N Clamp on Filter
    Mar 2003
    NJ
    911
    was the metal steel or aluminum?
    86 KXT250B1 (4)
    87 KXT250B2
    85 ATC250R
    85 ATC350X
    84 ATC200S
    87 Banshee
    96 ZX7R
    May 2003
    556
    both, i am doing mulitple parts
    85 Tri-z
    38mm Flatslide
    Boysen Power Reeds
    Bored 1.25mm over
    K&N Clamp on Filter
    Mar 2003
    NJ
    911
    go to a paint shop and pick yourself up some clear coat then for the steel. aluminum you do not have to coat.
    86 KXT250B1 (4)
    87 KXT250B2
    85 ATC250R
    85 ATC350X
    84 ATC200S
    87 Banshee
    96 ZX7R
    May 2003
    556
    alright, thanks
    85 Tri-z
    38mm Flatslide
    Boysen Power Reeds
    Bored 1.25mm over
    K&N Clamp on Filter
    '86X is offline First Time Rider Arm chair racerNew to the board
    Jul 2003
    136
    after polish
    There is a sealer for polished aluminum that will reduce upkeep on it. One what I know of is called Zoop seal. It is supposed to keep a good polish look for 2 years.
    '86 ATC 350 X FOR SALE-- GONE!
    '86 ATC 200 X PARTING OUT
    '95 Banshee--The most feared ATV ever built
    '95 KX 125
    '98 Polaris 700 XCR
    '65 Mustang!!
    May 2003
    556
    alright, do you know where i can get some?
    85 Tri-z
    38mm Flatslide
    Boysen Power Reeds
    Bored 1.25mm over
    K&N Clamp on Filter
    Jul 2003
    136
    Zoop seal
    Check www.spiketv.com. Go to Trucks! (tv show) section. I saw it on that show.
    '95 KX 125
    '98 Polaris 700 XCR
    '65 Mustang!!
    Feb 2003
    485
    Clear aridite.
    Nov 2001
    B.C.
    933
    :?: What's aridite? :?:
    Join The Trike Registry Now!
    http://fly.to/TrikeHeaven
