Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 45
Thread: My ATC250ES, my baby...
    djm0242's Avatar
    djm0242 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2011
    Rockwall TX
    297
    Cool My ATC250ES, my baby...
ID:	160949Click image for larger version.
ID:	160950Click image for larger version.
ID:	160951Click image for larger version.
    Ok here's the deal. I went to buy a 350X. The 350X was really a 250R with a 350X engine. I sadly told the guy- "sorry I really want a real 350X." As I turned around there she was, my 85 ATC 250ES busted, rusted, beat, broken, and engine in the locked position. Metal tank missing, side covers gone. Rear brakes seized, all of this hidden slightly- obscured from full view by a rotting blue tarp. I asked what do you want for that one over there? We looked at it- he shrugged his shoulders... $100? I said ok
    That was 6 months ago. So what did it need? Why was it locked up you ask? The exciter coil was bad. It sat for so long because of a $30 part. The top end was locked because of sitting for 8 years. I bought some Marvel Mystery Oil. (By the way if you aren't using this stuff- you are missing out on something your fathers knew about long ago.) Top cylinder lubrication is a must for long lasting air cooled or water cooled machines. I removed the spark plug and poured a few oz into the chamber. I walked away for three days. I came back and removed the engine case plug to reveal the fly wheel bolt. I spent a few minutes turning left and then right gently and when the crud inside broke free there was a wonderful shower of red oil as the piston travelled to the top of the cylinder! A few days later my eBay won Clarke tank arrived and I was almost ready to ride. I pulled the rear hubs to inspect condition. It was tough from sitting so long. I packed everything with grease and she was ready to go. The rest is history- new plastics, rear Atv basket, brakes, bearings, wheel spacers, front shock rebuild with seals and boots, larger carb upgrade, new lenses, decals, rear bearings from All Balls. 14" SS 212's with BajaCross 8ply tires.
    Sarnia, Ontario, Canada
    3,415
    Looking pretty badness..but you're in for a few on that project!
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Jan 2011
    Choctaw, OK
    2,755
    Nice rescue on the ES. I am hosting a ride at Little Sahara OK the first weekend in May. load up your ES and come on out. There is a thread on it. You're in Rockwall so your not that far away.
    djm0242's Avatar
    May 2011
    Rockwall TX
    297
    Oh yeah I'm locked in with a pretty good investment! I got a good deal on just about everything I've bought and I do all the work myself so it's not too bad
    djm0242's Avatar
    May 2011
    Rockwall TX
    297
    Thanks for the invite FlyingW. I've heard of Little Sahara but never been. Ill check it out!
    Jan 2011
    Choctaw, OK
    2,755
    Here's the tread. I'll post more details soon.
    http://www.3wheelerworld.com/showthr...-Trike-Rampage
    fingerlakesny
    2,834
    turned out great = whats the hose coiled around the handlebar for ? does that hook-up to a tasty drink on your helmet ?
    250r dust runner
    djm0242's Avatar
    May 2011
    Rockwall TX
    297
    Hey 123456. I put that clear hose on the rear differential and was in process or routing it through the frame when I noticed I was running out of day light. I am trying the clear hose so I can keep a close eye on contaminants. I also want to know if I lose a seal. My theory is that if the differential gets filled with water and mud I should see a mess in the tube and then ill be able to catch something early instead of destroying it.
    NEPA
    7,051
    Gorgeous machine sir. Very nice, I love it.
    Lewiston, N.Y.
    1,477
    niiiiiiiiiiice
    May 2011
    The Granite State
    914
    great job! let use know how the decals hold up on the plastic tank if you can
    86 350X ::: 85 250R
    Projects
    350x
    Come and Gone
    86 350x : 84 250r X2
    85 350x X2 : 84 200es X3
    83 200e : 78 ATC90
    djm0242's Avatar
    May 2011
    Rockwall TX
    297
    Actually I fought with them. They bubbled up and I pulled them off. I wrote the people I got them from and they said they didn't know what the problem was. They sent me another set and they bubbled up too. so now I'm frustrated. Anyway I put them back on the backing that they peeled off of when new. I put the matting back on the top. I took a hot iron and carefully ironed the bubbles used a pin to let the air out and got them good and hot. Let them cool off and pulled the backing off again and sprayed them with 3M spray adhesive really well. They don't seem to be bubbling up now. Time will tell. I bet you've been through the bubbling up thing before too?
    Hampton, Virginia, C.S.A.
    2,664
    it looks like you made a 2inch? lift for the rear? that is a good looking red.
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    May 2011
    The Granite State
    914
    Quote Originally Posted by djm0242 View Post
    thats why i was asking, usually w/ plastic tanks you need special decals with little slits in them so the can breath w/ the tank itself
    86 350X ::: 85 250R
    Projects
    350x
    Come and Gone
    83 200e : 78 ATC90
    djm0242's Avatar
    May 2011
    Rockwall TX
    297
    Thanks threewheelin! - I just bought an aluminum bracket for $2 from eBay- it's on my page. It was too easy and works great.
