Results 1 to 15 of 23
Thread: Big wheel problems
    Jan 2011
    Brazil, Indiana
    2,087
    Big wheel problems
    Well I was enjoying my BW200 that I have had for 2 weeks yesterday. When it started making a ing noise from the top end. If you let off of the throttle and pull in the clutch it dies like you flipped the kill switch, but will power through it while running rough. It always starts right back up and would run fine for a few more minutes till it done it again. I have eliminated any shorts in the wiring. I am leaning towards a sticky valve, broken valve spring, or slightly bent valve since it will come out of it. I assume the ing is the rocker hitting the valve. I tried some seafoam and marvel mystery oil to clean and free the valve. Nothing worked. Looks like i am going to have to tear the top end off to take a look.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    Baltimore, MD
    6,088
    Did you run a compression check? Pull the plug and inspect that? Check your valve chain tension? Check oil? Check timing? Start simple first. Maybe the decomp?
    Nicholson 500x (Project)
    Nicholson 185s
    PK Racing Suspension 70
    A+ Inc Suspension 70
    AWS Aluminum 90 frame
    Jan 2011
    Brazil, Indiana
    2,087
    I adjusted the cam chain and timing per the ytm200 manual. Ialso unhooked the decompression cable, no difference. Fresh oil and filter. It just about has to be in the head. Cant see a compression test telling anything since it will run fine till it acts up then once it dies, runs great again. That is what makes me think sticky valve taking too long to close.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    Gold Hill, OR
    1,295
    Might be time for a 225 swap!
    Joker 90
    1981 Yamaha YT125
    1986 Yamaha Big Wheel 80
    1986 Kawasaki Tecate KXT500
    1987 Kawasaki KXT250B2
    2005 Yamaha YFZ450
    Oswego NY
    1,935
    Did you leave the fuel on? Could it be fluid locked?
    I have had this problem on my T3s, my P3 and just fought it w my GFs trailblazer250. The blazer would run then build up pressure and either just die or it would backfire than die. I cleaned carb, new plug ect befor i found gas in the base.
    MIK6/ Mike
    New England Ride 4/13
    Gold Hill, OR
    1,295
    Quote Originally Posted by MIK6 View Post
    MIK6/ Mike
    That's more of a two stroke issue with the crankcase filling with fuel.
    Joker 90
    1981 Yamaha YT125
    2005 Yamaha YFZ450
    Jan 2011
    Brazil, Indiana
    2,087
    MIK6/ Mike
    No, the fuel was shut off before storage. It did it before I did the oil change. I thought it was starved of oil to the top end. I loosened the screw on the head and plenty of oil came out. I am afraid I am going to have to go inside.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    Oswego NY
    1,935
    Quote Originally Posted by ezmoney1979 View Post
    I agree its a 2stroke issue, but prairie700 (which i also have lol) are known to do it as well. Just something i always keep in the back of my head when something wont start.. lol
    MIK6/ Mike
    Doink's Avatar
    Doink is offline At The Back Of The Pack Arm chair racerFirst time rider
    Mar 2011
    northwest SC
    168
    The noise is definitely worth investigating, but it is very possible (probable, even) that your CDI is shot. Start searching for an affordable one now. I have read, heard and experienced the very same problem you are describing. A new CDI won't be cheap, so eliminate everything else before you put money down.
    "If it were easy, everyone would be doing it."
    1987 Yamaha BW350 (dealer find, never oiled or gassed)
    1990 Suzuki DR350 Fat Cat/ Big Wheel conversion
    2011 Suzuki KingQuad
    Jan 2011
    Brazil, Indiana
    2,087
    Are the CDI's the same as the ones from a ytm200?
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    Doink's Avatar
    Mar 2011
    northwest SC
    168
    No compatible unit has been found for the BW200 CDI so far. If you try a ytm200 and it works, let me know. I'll be VERY interested.
    Mexico
    9,018
    I'd open the carb and look for a piece of junk that could be causing it to lean out before you pull the top off it. You might get lucky.
    Jan 2011
    Brazil, Indiana
    2,087
    I cleaned the carb the day I brought it home. It had been sitting for a while in the guys barn.
    When it dies, it is like some one flips the kill switch. There is no stumbling like it is running out of gas. And the funny part is it will start right back up 2 seconds after it dies.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    Mexico
    9,018
    Quote Originally Posted by hoosierlogger View Post
    I had a very similar issue on another bike. In the end the problem was a piece of steel-wool leftover from a cleaning that was wound up like a spring in the main jet causing it to curl up and close when under load causing the bike to stall and then allowing it to start and idle a few seconds later. I am speculating that your “knock” which I understand to be intermittent, could be caused by detonation brought on by an extremely lean condition which is occurring just prior to the engine stalling. That said I haven’t heard and felt what is happening, so I may be 180 degrees off, but the combination of symptoms you are describing seem to rule out a valve train/piston failure.
    You may be right, it might be in the head, but you may just have a plugged, or loose jet, a sticking float or a clip off the needle. If it’s not the carb you’ve lost 15 minutes of your life, but if you open that head for no reason you have lost a lot more.
    Jan 2011
    Brazil, Indiana
    2,087
    After a thorough session of beating on it and paying close attention to what it is doing, It only seems to be happening in the mid range. It will sit and idle forever. It runs WOT no problem as long as you have the room to do it. It only seems to happen in the mid range. Ill go through it again as soon as I get the time.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
