Thread: will a 83-84 250r front end fit my 83-85 200x frame
    Oct 2008
    Reedsport Oregon
    856
    got a 200x im building, found a nice full front end off a 83 250r i noticed the replacement steering stem bearings (mine are shot) are one part # different? will this front end accept 200x bearings? want to find out before i wast 40$ on bearings
    thanks
    Apr 2006
    SE CA Dez in the sandbox
    892
    Did you use the search function for an answer?
    http://www.3wheelerworld.com/showthr...nt-end-on-200x
    Oct 2008
    Reedsport Oregon
    856
    yes on bikebandit.com its one part # off? i just dont want to order the bearings if its a waste of time, i know a 350x front end will fit
    Sep 2011
    Ocean Beach, CA
    1,333
    order the 200x bearings since its goin in a 200x frame
    the stems are the same sizes for both 83-85 200x and 83/84 250R so if you order the 200x stem bearings, you'll be able to use them without modifying anything
    Southern MN
    1,875
    You could also always bore out your tripple trees to accept the 250r forks. I believe if you swap the trees, you loose some rake, because the 200x tripples have the rake built in. Also, the 200x headlight bracket will not bolt right up, and the front brake line will be too short, so you may need the 250 line. I was looking at my 84 R forks side by side to the 200x the other day, they are at least 3 inches longer. I beleive you would have to run the R front rim and brake as well. I know the front axle is shorter on the R. Just some things to keep in consideration.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Apr 2006
    892
    Quote Originally Posted by manbearpig View Post
    the stems are the same sizes for both so if you order the 200x stem bearings, you'll be able to use them without modifying anything
    I agree, from the original post it would appear that the entire front end is being swapped out. .
    I guess I've missed something.
    I've done that swap several times a few years ago and I don't remember having any problems.
    However, that's before I put 350X front ends on 200Xs
