here mine with the wood repair done ... I hear ya Regina!!! gettin old!!plan on a rack on the roof for racing!
replacing the partical board with one side sanded .. for the beds should make it last twice as long.. thanks for this post....you just put a bug in my ass to get new canvis!!!!
yea it was me..LOL you got a link to that rack for your camper?
It has been my plan since I seen one roll into TF. The plan I have will anchor the roof rack to the main frame but will also allow it to be set up withouth removing the rack. I'm just waiting to find a tandem axle camper,not because I am worried about the weight but because they usually have a bigger box which = more trikes on the top![]()
So you did see one Ben? With trikes on it.. Did you look at the racks were they home made?
86 Tri-Z
86 Honda 250R,
84 Tecate
Man i wouldnt risk that... I have owned and worked on many PUP's over the years, i never had one that would support more than a roof mount AC unit on it, let alone a rack and a trike. The biggest issue is that most of them are on the hairy edge of the axle rating even without your stuff in it. If your going to haul anything on the roof the first thing you need to consider is the axle, tires, and weight. I would bet your going to need new tires at the minimum, most of them are rated for about the amount the axle is if that. Especially if you have the little 8" tires. If you have 8" tires expect an upgrade, axle, bigger wheels and tires, etc. Also make sure your camper is a full axle, some of them PUP's have what amounts to spindle style axle on either side, put any extra weight on the roof that changes the center of gravity and man do they roll on the curves and turns. If you have a solid axle you might even need to beef up the springs, even if the axle would happen to be rated for more i doubt the springs are.
I have been through this many times. I have rebuild the winch setup on a few PUP's because someone added a rack to the roof and stressed it. You have to consider the dead weight your adding even when you take the trike off. Are you going to also remove the rack before setting up? If not then you have to take that weight into account as well because the cables and winch to raise it now have that extra weight. I have installed a roof mount AC unit and had cables pop before, boy was that fun, another weekend and new cables fixed it, but sure was scary as hell!
1984 Honda ATC200ES "Big Red"
1982 ATC200E "Hondie"
I'm only lookin to carry 1 bike on top.... I was thinkin a alum rack or eyelets and wheel chock points.... mine has the same axle as my sled trailer so I'm not worried. no cables here manual lift so lighter the better!
Between those having crap frames, and junk axles.....I wouldnt try that.....
1985 Honda 250R 1985 Honda 350X
1985 Yamaha TRI-Z 1986 Yamaha TRI-Z
1986 Honda 600x 1986 Honda 350X
1985 Honda 70
Grab your Genesee and let your mullet fly, were trike riding!
