Results 1 to 15 of 21
Thread: Wood stoves ?
    fingerlakesny
    2,834
    Wood stoves ?
    ANYONE HAVE A WOOD STOVE THAT DOES'NT REQUIRE A PIECE OF WOOD EVERY HOUR JUST TO KEEP IT GOING ? my old one just eats the 28 " logs rite up.. atleast 1 per hour... ive heard of stoves burning overnite without adding wood and just wanted to know who makes a good one ?
    250r dust runner
    Columbia
    5,131
    You should look into a pellet stove! No more cutting wood. I heated my old farmhouse with one. It was a very, very drafty house. Pellet stove did great. Ate about 2 bags a day when you had it turned up on high. Was about $200 a month in pellets verses the $500 in propane. Also saved almost $100 a month in electricity without the furnace constantly running.
    If your open to that you wont regret it.
    Nov 2010
    Oshawa, On, Canada
    2,123
    We burn wood in my house in the city, cottage, garages. Works perfectly fine, seems to me you are burning soft wood. I throw one or two nice 15" pieces of hardwood in there everynight before bed, I wake up in the morning and there is enough hot coals to start it up with ease. Softwood is alright for during the day when you are home, but if you are not home, or if it is night, hardwood is the way to go.
    Pellets sure do seem expensive to me, considering we cut all our own wood off of our bush property for free. But I guess considering the price of propane and gas, its a lot cheaper.
    Also, how F'in big is your woodstove to hold a 28" log? Do you live in a 100000 square foot house? Seems way overkill.
    1985 Honda 250r x2
    1986 Honda 250r
    1986 Honda 250sx
    1985 Honda 250sx x2
    1985 Honda 350x x2
    1986 Honda 350x
    1984 Honda 125m x4
    1984 Honda atc 70
    Yamaha tri zinger
    Yamaha 4 zinger
    Brap braaaap
    Jan 2011
    Brazil, Indiana
    2,087
    I used to have a wonder wood stove. It would take up to 24". It was firebrick lined. I think it cost $400 about 10 years ago.
    Current rides
    Taurus 650 (green)
    85 250es big red
    82 ALT50
    82 ALT50
    71 QA50
    93 TRX 300 FW
    Columbia
    5,131
    Quote Originally Posted by Jason125m View Post
    Sure in a position where you have the land, and the extra time to cut, split, and haul wood it seems cheaper and easier. With my schedule, and for $150-$200 a month your dammed sure Id rather buy a pallet of pellets. Maybe Im just lazy. I weighed the options when I bought my stove, and ended up not wanting to have to deal with cutting wood.
    ct
    1,396
    I agree with a pellet stove. I have 2 woodstoves and go through around 7 cord of wood a year. I have been burning wood for 10 years now. I used to have access to "free" wood. ( dont forget to figure your time, gas, saw maintenance " and you will realize it's not free. I do enjoy cutting a little wood but honestly the novelty wore off a few years ago.
    I buy my wood now and most of the time the quality is fair at best. Pellet stoves are the way to go unless you have access to "free" wood and really really enjoy it. Remember it takes about 2 years of seasoning to burn hardwoods properly in a woodstove.
    fingerlakesny
    2,834
    homemade 24" id pipe stove.. 48 " long... heats great but eats it... we have free wood and dont mind doing it .. but want a efficient stove...
    250r dust runner
    I've been burning wood since I was a kid. I'm 33 years old now. Pellets are for the birds.
    I heat my house with wood and wood ONLY. I have a oil-fired boiler, but my oil tank is empty. I use the boiler rarely if I'm going away for a day or two, but that's it. I don't even have that option right now because my oil tank is empty, like I said. My house isn't insulated and has the original windows from the 50's, yet it's usually about 75+ degrees in here. I go to my friend's nice, new, insulated houses and I can't take my jacket off because I get cold.
    My stove will burn for 8 hours. It is a Russo CW2. It can also burn coal, but I never do. Wood is free.
    I'm willing to bet you don't have a chimney liner, 123456q (nice name BTW). I made that mistake for years. Growing up I was just feeding the stove in my parent's house. I don't know how theirs was set up, I was younger and unconcerned. It was just part of the day. When I bought my first house in '05, I put in a Russo CW2. I ran that stove for over 5 years with no liner. It heated the house great, but it absolutely chewed through wood. Then I bought my second house in 2009 or 10, and I again bought a Russo CW2. I ran it for a year in this house with no chimney liner, but then I put a chimney liner in. Let me just say right now, I should have done the liner years ago. I had people telling me to put a liner in for a long time, but I really didn't listen. Then one day my buddy gave me a liner. He had bought one for his house and he only needed half of it, so he gave me the other half. Prior to installing the liner, all I had was about 4' of black pipe going up the chimney. This was wrong for so many reasons and I'm embarrassed I ran the stove that way for as long as I did. The liner goes straight out the back of my stove to a "T", then it goes to the top of a chimney with a cap on it. Before I had the liner, I would rarely shut the intake damper on the stove and I had never shut the exhaust damper even one time. The stove would just die. I used to just run it on full blast all the time. Now, with the liner in, it runs so efficiently that I have to close both dampers all the way just to keep the stove from overheating. I'm sitting next to it right now and it's a little over 700 degrees with both dampers closed all the way.
    Two winters ago, I had to take my cruddy old black pipe out of the chimney 3 times during the winter because it would clog solid with creosote. With the liner in, if any creosote builds up, it just flakes off the pipe and falls down to the bottom of the "T" where it collects and piles up and then eventually burns off harmlessly. No more cleaning crappy pipes.
    If you don't know how a chimney liner can make your stove burn hotter, longer, and more efficiently, let me explain it like this- Have you ever tried to run an engine with no exhaust? Like, no head pipe, or an open header? It runs like crap pretty much across the boards, aside from maybe wide open, right? A wood stove works the same way. The exhaust (in this case, the chimney liner) is a critical part of the combustion process.
    You'll want something like this- http://www.ebay.com/itm/Stainless-Fl...item3a70093b5c
    Another issue you might have is you may have a "loose" stove. The more air you feed it, the more wood it will burn. It has to be air tight or it will always suck air and fry your wood supply.
    Jul 2011
    Cato, NY
    33
    I only post when I feel I have something to add, but Fabio already hit upon it. Still I can say that dampers, both chimney and draft dampers are very important to controlling the burn characteristics of your fire. My wood stove is not very big, about 18"x12". When I'm cutting, I cut some of my wood short enough to fit in endwise, the butts facing towards the door. (The door is on the front.) This way I can really stuff it full, like a bookshelf. I don't cut it all that short as it is a real bugger to stack. Out of the usual 14 face cord I use, I'll cut 3 cord short and only use them as night time stockers. The longer legnths just don't seem to fit in there right trying to put them in there sideways. Then they want to roll over and block my intake draft. Doesn't seem to make much sense, smaller wood for a longer fire,but it works for me. Just an idea. I always add the following when conversing about fire, check your smoke detectors and keep a fire exstinguisher handy.
    I have been burning wood since I was about 6, I had to keep the inside fireboxes stocked, and am almost 45 now. To me there is no substitute for wood heat. My burner is in the basement and I keep the basement door open and it convects up here quite nicely. I can keep it around 73* up here unless it is super cold out, then my propane furnace, that is set at 68* will kick on 2-3 times a day. Good luck on figuring out your dilemma.
    Scootertrash's Avatar
    In the sticks
    4,638
    I guess I'm not really sure what a "pipe stove" is, is this a homemade stove using an old 55 gallon drum? (We call them barrel stoves) If that's what it you are talking about, those can only be so efficient. My guess is that your dampering/air feed system is less than adequate, or as Fabio said, you have a stove that leaks a lot of air. You should have a damper on the flue and some type of control for the air feeding the firebox
    How dry is your wood?
    fingerlakesny
    2,834
    welp, its a 24" round heavy as heck x 48 " long. welded cap on 1 end and has a nice door on the front with a adjustable air inlet. we used to have a damper on it but if we closed it a little bit smoke would blow out the air vent in the door... it has a concrete chimney with the orange virus tile chimney inside ..
    250r dust runner
    NEPA
    7,051
    I'm willing to be you don't have a chimney liner, 123456q (nice name BTW). I made that mistake for years. Growing up I was just feeding the stove in my parent's house. I don't know how theirs was set up, I was younger and unconcerned. It was just part of the day. When I bought my first house in '05, I put in a Russo CW2. I ran that stove for over 5 years with no liner. It heated the house great, but it absolutely chewed through wood. Then I bought my second house in 2009 or 10, and I again bought a Russo CW2. I ran it for a year in this house with no chimney liner, but then I put a chimney liner in. Let me just say right now, I should have done the liner years ago. I had people telling me to put a liner in for a long time, but I really didn't listen. Then one day my buddy gave me a liner. He had bought one for his house and he only needed half of it, so he gave me the other half. Prior to installing the liner, all I had was about 4' of black pipe going up the chimney. This was wrong for so many reasons and I'm embarrassed I ran the stove that way for as long as I did. The liner goes straight out the back of my stove to a "T", then it goes to the top of a chimney with a cap on it. Before I had the liner, I would rarely shut the intake damper on the stove and I had never shut the exhaust damper even one time. The stove would just die. I used to just run it on full blast all the time. Now, with the liner in, it runs so efficiently that I have to close both dampers all the way just to keep the stove from overheating. I'm sitting next to it right now and it's a little over 700 degrees with both dampers closed all the way.
    Damn well put Fabio,,this,along with the link,, should be a sticky for ANYONE who does,will, or even thinks about burning wood..
    Sep 2009
    Suring Wisconsin
    967
    I put in an outdoor central wood boiler and love it. Right now it is 5 below zero out and it is 75 in my house. I burn any wood that I can get, Been heating lately on spruce with a little elm. My whole yard smells like a Christmas tree. I heated with wood for years and my wood stove in the basement would puff back when the damper was closed most of the time that is because of an air leak or to hot of fire dampered down. For me it was air pressure change from inside basment to out side or if the wind would blow just right and go down the chimmny. A liner would have cured that I beleive but I was saving pennies for my outdoor one. Next year my shop will be heated off the boiler also.
    Rebuilding and riding trikes everyday and lovin every minute.
    http://www.3wheelerworld.com/showthr...light=pipeline
    In the sticks
    4,638
    Quote Originally Posted by 124356q View Post
    Is your chimney the proper height above the roof line? Sounds odd that it would backdraft like that, by closing the damper just a little. hmmmmm.....
    Is this in your house or in a detached garage or outbuilding? Just wondering about how air tight the building could be....
    Abrams, Wisconsin
    739
    ^^ I' ve got an outdoor boiler also, works great. It holds a lot of wood, I only load it once or twice a day depending on weather. As pipeline said, no risk of chimney fire so you can burn anything. I also heat my hoy water with it. Once my labor force is grown up and moved out, I might get sick of cutting wood though lol.
    86 250sx - old reliable
    another 82 110
    -gone but not forgotten-
    82? 110 - why did i sell it??
    84 225dx - meh, it was a pile
