Results 1 to 15 of 61
Thread: My 86 250R ice racer has evolved again! This time it's a monster!
    Aug 2002
    New York
    1,098
    Many people on this board have seen my R's posted over the years. I go through the bike every few years to update it, fix broken or worn out parts, try new set ups and pretty much play with my favorite toy. I got this bike as a parts bike in 1997 when I bought my other 1985 R. I built it up from scratch. There are only 6 original parts left on the bike. Everything was replaced, updated, modified etc over the years.
    Here is a video that brings us up to 2006:
    Well the ESR330R motor was a good motor for what it was, it was time for a bottom end rebuild and that set the wheels in motion to build a motor I have wanted for years. I also found out that I had cracked my -1 Westcoast swingarm. While it made the bike a ton of fun to ride, it ultimately hurt me in a lot of races so it had to go.
    So I pulled the motor and shipped it off for a rebuild. I rebuilt every part of the bottom end. All new transmission with Yukon gears, shift forks, an 8 plate clutch mod, all new bearings, new clutch upgrade kit, clutch pivot arm, billet basket, clutch hub, crank....everything except the main and counter shafts and the gears that connect the crank to the clutch basket. I sent the motor to FTZ Racing as they I have had good experience with them in the past. I will also be rolling out my old FTZ 250 motor in my 85 R this year, but that is another story.
    I then started accumulating parts for my next buildout:
    A Lectron 48HV from Packard Enterprises.....Dennis is a great guy and super helpful.
    A Westcoast +2 with double coating of powder. FYI, if you use a glossy white powder, it is runny when baking and ultimately does not cover well. Look at my -1 Westcoast above. The powdercoater has agreed to repowder that swingarm again for free since that was only done a few years ago and should not have pealed so bad.
    Well, once I started getting parts back in I realized that to acheive what I wanted to do, I would have to make some modifications to get it all to fit. The carb bowl is a 200% capacity bowl, but would not clear the kick starter gear so I had to modify the bowl to fit.
    I also had to modify the frame to fit this monsterous carburator:
    I then got the pipe in from Nick "NOS_350X"
    I sent that out to be ceramic coated:
    Next was the intake: I need to run an airbox when we ice race due to all of the snow and water flying around so I had to custom build a box. I built the box so it could be separated from the intake boot. That way, I can choose to run the box or just an aircleaner.
    I also modified the case to fit a 16 tooth front sprocket.
    Ha ha Ha seems like were all evolving at the same time... Nice Buddy!!!!! gonna have to keep the tracks small so you dont stretch it out!!! lol
    should have said something I got one of them carbs .. all you had to do is change the needle.. Did you run it yesterday????????????????? we would have drove 4 hrs!!!!! lol
    Feb 2006
    Texas
    738
    Damn, every time I see this bike it's more amazing than the last. And every time I think nothing more can be done to it.
    Keep up the great work Chris.
    TORKER.
    THOSE WHO SAY IT CANNOT BE DONE, SHOULD NOT GET IN THE WAY OF THOSE BUSY DOING IT...
    Aug 2002
    New York
    1,098
    I also had to swap out the HRC Mugen rear suspension for a Works shock because I could not get the larger intake tract to fit with the reservoir.
ID:	161365 Click image for larger version.
    I also had to make sure my large carb was getting enough fuel so I invested in a Pingle fuel valve. I also put a pulse port in the cylinder for a fuel pump if I need it. Right now it is capped off.
ID:	161367 Click image for larger version.
    Well, the motor was something I could not do myself as I just don't have the tools nor the knowledge to build this motor. I have been through the bottom end of my bikes many times over the past 25 years, but epoxy, case boring, decking, setting port timings are way out of my league. FTZ did a nice job on the motor, so we will see what it can do. Introducing the CP Industries 431 Puma motor.
ID:	161369Click image for larger version.
ID:	161370Click image for larger version.
ID:	161371Click image for larger version.
    I finally got it all in....barely.....and am looking forward to breaking it in. More pictures to follow....
    you got a problem mr!!!!!!!! holyshit!
    May 2003
    Houston, Texas
    2,409
    Holy Moly!!
    I have heard those things are killer...but they chomp through the 250R trannys pretty fast.
    SEND ME PM HERE - CLICK HERE
    Dirtbikes:
    1988 Yamaha DT
    1,641
    That is one extreme R!Awesome!
    he already has a updated stronger tranny... from his 330.......
    rjs89ia's Avatar
    rjs89ia is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2010
    Kingman, AZ
    271
    Seeing your R makes mine look like it came out of a dumpster , nice work man can't wait to see some vids of this monster digging trenches on the ice. quads beware!
    Aug 2002
    New York
    1,098
    I am waiting for files to upload so you can see it all together. Thanks for the kudos! To avoid the tramsmission explosion as much as possible, EVERYTHING in it is new with brand new Yukon gears. I can't wait to get it on the ice.
    No, I didn't get it out yet. The ice was sketchy there. It is also 4 hours from me too as I am in Maryland. I will be going to our place in GWL next weekend, ice or nor ice.
    Aug 2002
    New York
    1,098
    Aug 2002
    New York
    1,098
ID:	161373Click image for larger version.
ID:	161374Click image for larger version.
ID:	161375Click image for larger version.
    1,641
    One question.Did the pipe mount not line up?Only reason I ask was looking at his pipes.Or was it made for a stock R?
    Quote Originally Posted by ChrisD View Post
    let me know next weekend ....sub zero temps heading at us...
    Frewsburg NY
    1,169
    Love how u kept this a secret. Even posting about my 370 and how you are just going to run the 250. Hahaha. Got me thinking since my motor is still in pieces that I need to step it up already. Doubt I will make this ice this year anyway. Nice build for sure chris.
