Results 1 to 9 of 9
Thread: Rear Brakes
    Jan 2013
    texas
    88
    Rear Brakes
    Can someone tell me how hard its gonna be to install new shoes on the rear of my 85 big red es. any tips will sure help me thx. ahead of time
    Jan 2011
    Choctaw, OK
    2,755
    Remove the right wheel.
    Remove the right hub.
    Loosen both brake cables.
    Remove the brake drum.
    Remove and replace the brake shoes.
    Clean the inside of the brake drum.
    Scuff the inside of the brake drum where the shoes contact with about a 220 grit sandpaper.
    Clean the brake drum again.
    Reassemble in reverse order
    Referance the factory manaul. It takes about 30 minutes assuming you have no problems getting things to come apart.
    Jan 2013
    texas
    88
    can i get shoes on e=bay
    Jan 2011
    Choctaw, OK
    2,755
    Oh ya, for sure. Just search for ATC 250ES brake shoes. Readily available
    Oct 2012
    Finlayson, Minnesota
    1,066
    Not sure if you've ever done it.. i'm guessing no sense you're asking the question lol.. but a tip for that break drum if it is the same as mine was.. use Heat and a lot of it if it's stuck. I heated mine up and was hitting it with a before it broke loose. Those things tend to get stuck and corroded.
    Jan 2013
    texas
    88
    thanks guys. it helps when you have back-up on these projects. your support means alot. im sure i will have more questions....
    Jan 2011
    Choctaw, OK
    2,755
    Thats why we're here.
    Jan 2013
    texas
    88
    ordered new rear and front shoes on e-bay this morning.will start on the grunt work when it warms up abit . sprayed pb blaster on lug bolts, they looked pretty rough and rusted. i bought a soda blaster and that should help with the clean up. thx guys for helping me out........
    Oct 2012
    1,066
    No problem Elevatorman, Good luck!
