Hey guys im in the middle of splitting my case.. im just NOT sure how to remove these two parts. Clutch basket? i think it's called and im not sure the other part.
Thanks!
Thanks!
You must remove the front clutch, take out the three bolts, under that will be a big nut. The second clutch requires a special socket. I've made one before but using a Dremel to cut a socket. Hope you have an impact gun.![]()
Yes, an impact is needed to get the nut off. Unless you can hold the clutches which I don't recommend doing by hand. Didn't you say you have a manual? It will cover all of this. Also, it may be easier to keep your questions in one rebuild thread, that way there isn't 40 threads within 2 weeks on simple questions
Thank you! I may be able to get it now. How about the clutch basket? For the special tool is that to remove the flywheel behind the magneto and recoil? Yup I have an impact =) That's the only reason i'm as far as I am lol
the special tool is to get the nut off that holds the clutch basket. I made one from a socket also using an angle grinder.
How do i delete threads lol.. i've tried deleting like 30 of them but don't how. Yes i've got a manual but I couldn't find it. The only video I saw on youtube was a guy beating it out with aso i figured i'd ask here.
