thinking about building a 86 200x. what are some good mod for these
Not much available for the 2nd Gen X. Maybe someone else could chime in
Good mods for an 86 200x are the same as any other 3 wheeler. The only difference is the parts are few and far between.
Although if you want to add about 50hp could try adding the ever so rare![]()
I built my 86 200x that I had since new last year and was amazed on the availablity of parts for it. These are allot cheaper to build compared to a 250r. You can get pistons in different compression ratios from wiseco, 3 different cam grinds and springs to match from web cams and you need to send it off to Mickey Dunlap at 4 Stroke Tech for a valve job and a port and flo job. Here's a link to my build thread.http://www.3wheelerworld.com/showthr...22-86-atc-200x
Well I guess there is options for the engine but for other aftermarket parts there isn't alot that is available, at least that I have come across.
The parts are out there. It just takes longer to find them and some $ when you do. Check out my thread from last year. This one took me a few years. It has some hard to find items. Good luck with your X. The 86-87's are great bikes!
http://www.3wheelerworld.com/showthr...200x+resto+mod
Anything can be done to the 86/87 200X
I personally have never had an issue for these. There are cams out there, porting, larger carb, exhaust, etc etc.
I would not go 12:1 ever again because I have to drive a long distance to get fuel for it.
I'd go with a 10.5 to 1 piston as well as the other issues you want to upgrade.
